PMS HW Transcode fails after ~15 seconds of content
Server Version#: 1.41.0.8992
Player Version#: app.plex.tv
Server: Linux 64-bit
GPU: Nvidia Tesla P4
Driver: 550.90.12 (current as of this morning)
When I transcode a 4K HDR video to something lower resolution (like 720p SDR), initially transcoding works. I see a process pop-up in nvidia-smi. After ~2 seconds, the process disappears from nvidia-smi. The content that’s buffered in the player (~15 seconds) continues to play. When it reaches the end of the buffer, transcoding does NOT resume. The player just hangs.
nvidia-smi is empty and remains so indefinitely while the player is hung.
Plex Media Server.log (25.7 KB)
Transcoding settings:
  • [60 seconds] Default throttle buffer. Tried extending it to 120 seconds, to no avail.
  • [Medium] Background transcoding x264 preset
  • [Checked] HDR Tone Mapping
  • [Hable] Tonemapping algorithm. Tried others, to no avail.
  • [Unchecked] Disable video stream transcoding
  • [Checked] Use hardware acceleration
  • [Checked] Use hardware encoding. Tried changing, to no avail.
  • [Auto] Transcoding device. It’s clearly picking up the right device because I see it transcode briefly.
  • [15] Maximum simultaneous transcodes. But right now I’m testing with just one stream.
Confirmed that disabling hardware acceleration correctly falls back to CPU without issue. So it’s definitely a problem with Plex + GPU acceleration.
This morning I updated the nvidia driver from v525 and PMS from v1.28.0.5999. It worked before, so presumably one of those things are the issue…?
Unfortunately these logs are not usable (INFO/ERROR are insufficient)
  1. Please enable DEBUG logging - SAVE
  2. Restart PMS
  3. Recreate the problem
  4. Now download the Logs ZIP file
  5. Attach it here.
In the thread you split off, you said that the transcode problem was just in the web player. After setting up the test case again, I think you are correct. I tried transcodes with multiple other apps and it appears to be working.
I’m going to keep an eye on it for a couple days, but I think my problem is solved.
@ChuckPa: Thank you for your help.
P.S. I’d love it if Plex fixed the issue in the web player. There are times when opening a web browser on another computer is faster & easier than installing an application. Is there a way to vote for the dev team to fix that bug?
The issue with Plex/web will be fixed.
I don’t have the details but have been told they are re-writing it.
