PMS not properly parsing DTS-HD HRA track
PMS 1.13.0.5003
Debian 9 x64
I’m down to “S” digitizing my collection and I’ve come across Stargate which appears to be my first DTS-HD HRA disc. No issues with the rip and transcode, however PMS is reporting the audio track as “DTS Stereo” in the web client and “DTS-HRA Stereo” in the Roku client. The movie does play back successfully in a Plex client, but with only stereo audio.
VLC, MPC-HC, and Kodi all recognize the HRA surround track and play it back fine. The PMS Get Info and Mediainfo outputs are below.
I’m not sure if this is a PMS limitation, badly formed metadata, etc. Thanks!
PMS Get Info:
! Media
! Video Resolution 1080p
! Duration 2:10:00
! Bitrate 11244 kbps
! Width 1918
! Height 822
! Aspect Ratio 2.35
! Container MKV
! Video Frame Rate 24p
! Audio Profile hra
! Video Profile main
! Part
! Duration 2:10:00
! File Stargate (1994).mkv
! Size 10.21 GB
! Audio Profile hra
! Container MKV
! Indexes sd
! Codec HEVC
! Bitrate 10476 kbps
! Bit Depth 8
! Chroma Subsampling 4:2:0
! Color Primaries bt709
! Color Range tv
! Color Space bt709
! Color Trc bt709
! Frame Rate 23.976 fps
! Height 822
! Level 4.0
! Profile main
! Ref Frames 1
! Width 1918
! Codec DCA
! Channels Stereo
! Bitrate 768 kbps
! Language English
! Audio Channel Layout FC+LFE
! Profile hra
! Sampling Rate 48000 Hz
! Title Surround
! Codec PGS
! Language English
! Forced true
! Codec PGS
! Language English
Mediainfo:
! General
! Unique ID : 197956462032692508453823048032584870681 (0x94ED071D55D8C14C8D9CE5BBDCC22B19)
! Complete name : M:\Video\Movies\Stargate (1994)\Stargate (1994).mkv
! Format : Matroska
! Format version : Version 4 / Version 2
! File size : 10.2 GiB
! Duration : 2 h 10 min
! Overall bit rate : 11.2 Mb/s
! Encoded date : UTC 2018-05-03T07:12:58Z
! Writing application : HandBrake 1.0.7 2017052700
! Writing library : Lavf57.7.2
! Video
! ID : 1
! Format : HEVC
! Format/Info : High Efficiency Video Coding
! Format profile : Main@L4@Main
! Codec ID : V_MPEGH/ISO/HEVC
! Bit rate : 7 981 kb/s
! Width : 1 918 pixels
! Height : 822 pixels
! Display aspect ratio : 2.35:1
! Frame rate mode : Constant
! Frame rate : 23.976 (24000/1001) FPS
! Color space : YUV
! Chroma subsampling : 4:2:0
! Bit depth : 8 bits
! Bits/(Pixel*Frame) : 0.211
! Stream size : 7.25 GiB (71%)
! Writing library : x265 2.4:[Linux][GCC 6.3.0][64 bit] 8bit
! Encoding settings : cpuid=1173503 / frame-threads=3 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=1918x822 / interlace=0 / total-frames=0 / level-idc=0 / high-tier=1 / uhd-bd=0 / ref=3 / no-allow-non-conformance / no-repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=24 / keyint=240 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=20 / lookahead-slices=5 / scenecut=40 / no-intra-refresh / ctu=64 / min-cu-size=8 / no-rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=0 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=2 / limit-refs=3 / no-limit-modes / me=1 / subme=2 / merange=57 / temporal-mvp / weightp / no-weightb / no-analyze-src-pics / deblock=0:0 / no-sao / no-sao-non-deblock / rd=3 / no-early-skip / no-rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / rdpenalty=0 / psy-rd=4.00 / psy-rdoq=0.00 / no-rd-refine / analysis-mode=0 / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=22.0 / qcomp=0.60 / qpstep=1 / stats-write=0 / stats-read=0 / ipratio=1.10 / pbratio=1.00 / aq-mode=0 / aq-strength=0.00 / no-cutree / zone-count=0 / no-strict-cbr / qg-size=64 / rc-grain / qpmax=69 / qpmin=0 / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=1 / transfer=1 / colormatrix=1 / chromaloc=0 / display-window=0 / max-cll=0,0 / min-luma=0 / max-luma=255 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / opt-qp-pps / opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / no-hdr / no-hdr-opt / no-dhdr10-opt / refine-level=5 / no-limit-sao
! Default : Yes
! Forced : No
! Color range : Limited
! Color primaries : BT.709
! Transfer characteristics : BT.709
! Matrix coefficients : BT.709
! Audio
! ID : 2
! Format : DTS
! Format/Info : Digital Theater Systems
! Format profile : HRA / ES Discrete / Core
! Codec ID : A_DTS
! Bit rate mode : Constant
! Bit rate : 3 039 kb/s / 1 509 kb/s / 1 509 kb/s
! Channel(s) : 7 channels / 7 channels / 6 channels
! Channel positions : Front: L C R, Side: L R, Back: C, LFE / Front: L C R, Side: L R, Back: C, LFE / Front: L C R, Side: L R, LFE
! Sampling rate : 48.0 kHz
! Frame rate : 93.750 FPS (512 SPF)
! Bit depth : 24 bits
! Compression mode : Lossy
! Delay relative to video : 41 ms
! Stream size : 2.76 GiB (27%)
! Title : Surround
! Language : English
! Default : Yes
! Forced : No
! Text #1
! ID : 3
! Format : PGS
! Codec ID : S_HDMV/PGS
! Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
! Default : No
! Forced : No
! Text #2
! ID : 4
! Format : PGS
! Default : Yes
! Forced : Yes
! Menu
! 00:00:00.166 : :Chapter 1
! 00:04:17.173 : :Chapter 2
! 00:06:58.710 : :Chapter 3
! 00:10:41.307 : :Chapter 4
! 00:12:25.286 : :Chapter 5
! 00:16:29.280 : :Chapter 6
! 00:21:51.977 : :Chapter 7
! 00:26:43.518 : :Chapter 8
! 00:29:06.786 : :Chapter 9
! 00:33:40.310 : :Chapter 10
! 00:36:22.847 : :Chapter 11
! 00:40:28.843 : :Chapter 12
! 00:44:57.236 : :Chapter 13
! 00:51:31.880 : :Chapter 14
! 00:55:52.682 : :Chapter 15
! 01:01:43.658 : :Chapter 16
! 01:06:18.307 : :Chapter 17
! 01:13:12.471 : :Chapter 18
! 01:17:05.829 : :Chapter 19
! 01:24:16.259 : :Chapter 20
! 01:27:21.444 : :Chapter 21
! 01:32:08.106 : :Chapter 22
! 01:36:42.755 : :Chapter 23
! 01:43:26.909 : :Chapter 24
! 01:45:58.310 : :Chapter 25
! 01:49:46.872 : :Chapter 26
! 01:54:03.878 : :Chapter 27
! 01:58:34.148 : :Chapter 28
! 02:01:49.343 : :Chapter 29
! 02:03:41.956 : :Chapter 30
Same Problem with all my DTS-HD HRA movies.
Yeah, I ran into another one shortly after Stargate (Reservoir Dogs 15th Anniv) and saw the exact same result. Clearly PMS isn’t parsing the codec properly.
Same problem with all DTS HD HR movies.
I´ve noticed it first with Doctor Strange (BD german audio).
