The PMS can't show and use DTS-HD HRA!
Hello,
my PMS run on MacMini (Version 0.9.16.3).
my Client is Nvidia Shield TV
the Problem is, that the pms cant use DTS-HD HRA (High Resolution Audio), only the DTS Core!
If I have a movie with DTS-HD MA (master Audio) its running and the shield can play (only direct Play)
but not DTS-HD HRA.
any ideas, what the problem is??
thx
chris
Hello. I have the same issue in the same config (except the PMS that is on a Synology NAS). I’ts OK for DD Truehd and DTS-HDMA but not for DTS-HD HRA !
Any solution since your post ?
Same Problem here. DTS-HD HRA is shown as DTS and will not be played in Plex on Shield.
I tried different Movies (eg. Avengers: Age of Ultron and Dr. Strange).
Shield -> Denon AVR1300x -> LG OLED65C8
Problem still present after 3 years.
Hello, i know now the reason of this problem. this is the fault of reciveres with a Cirrus logic chip. the vendors promised a update for this problem since 2017. also new recivers from late 2018 are affected. watch out friends.
