PMS not starting
Hi there, I hope you are well
I wanted to know if you can please assist. I recently got the update for the new Windows 22H2 update. I am not sure if this broke PMS. I can see in my taskbar that PMS runs for 3 seconds and then it just goes away. I tried to look at the log in te Temp folder but I can’t figure out what the issue is.
Can you please assist?
Usually checking for any ERROR or CRITICAL lines could be a good opener to dig into the logs. As you seem to experience a crash, the critical lines should be towards the end of one of the numbered log file
Can you post your server logs ?
