PMS not updating to latest release
Server Version#:1.19.5.3112
Player Version#: 4.29.2
OS: Ubuntu 20.04 (x64)
Players report PMS is not on latest version (1.20.0.3181 at time of writing)
Howevre sudo apt update && sudo apt upgrade plexmediaserver tell me I’m on the latest release:
Hit:1 http://gb.archive.ubuntu.com/ubuntu focal InRelease
Get:2 http://gb.archive.ubuntu.com/ubuntu focal-updates InRelease [111 kB]
Ign:3 https://repo.mongodb.org/apt/ubuntu xenial/mongodb-org/3.4 InRelease
Get:4 http://gb.archive.ubuntu.com/ubuntu focal-backports InRelease [98.3 kB]
Hit:5 https://downloads.plex.tv/repo/deb public InRelease
Hit:6 https://repo.mongodb.org/apt/ubuntu xenial/mongodb-org/3.4 Release
Get:7 http://gb.archive.ubuntu.com/ubuntu focal-security InRelease [107 kB]
Get:8 https://dl.ubnt.com/unifi/debian stable InRelease [3024 B]
Fetched 320 kB in 1s (261 kB/s)
Reading package lists... Done
Building dependency tree
Reading state information... Done
All packages are up to date.
plexmediaserver is already the newest version (1.19.5.3112-b23ab3896).
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
I’ve made sure my sources are pointed to the right repo and added/accepted the key from the linux repo FAQ, and im fairly sure I’ve had at least some updates since installing Plex from this repo a few months ago.
Is the repo lagging behind the published version?
The repository only allows downloading/updating to public releases (latest public release is 1.19.5.3112).
If you want to install a beta version (latest public beta is 1.20.0.3181) you need to manually install it, e.g. using dpkg.
Edit: if you want to use public versions and not be informed about beta updates, you can change the update channel in Settings > [Server Name] > General > Server update Channel to Public
Thanks Tom, I’d completely forgotten I’d set it to the beta channel, and I wasn’t aware that the repository was only tracking the stable releases.
Makes perfect sense.
