PMS on Synology 918+ stops routinely
Server Version#: 1.18.5.2309
Plex Media Server Logs_2020-02-06_22-51-02.zip (5.9 MB) Plex Media Server Logs_2020-02-06_22-51-02.zip (5.9 MB)
Since adding a bunch of movies PMS stops running daily, logs attached. Thanks!
Same Issue here. With Ds918+
I had this happen yesterday. Had to go back into synology package center and “run” plex. Fortunately it restarted.
@keyspd
I’m getting a chance now to look at your logs.
Is the phone going to sleep? It shows in the paused state for a long time.
Feb 05, 2020 07:03:32.152 [0x7f128f302700] DEBUG - Auth: authenticated user 1 as keyspd
Feb 05, 2020 07:03:32.153 [0x7f126511f700] DEBUG - Request: [192.168.1.70:52804 (Subnet)] GET /playlists?playlistType=audio%2Cvideo&sort=titleSort (16 live) GZIP Signed-in Token (keyspd)
Feb 05, 2020 07:03:32.158 [0x7f128f302700] DEBUG - Completed: [192.168.1.70:52803] 200 GET /playlists?playlistType=audio%2Cvideo&sort=titleSort (16 live) GZIP 5ms 1056 bytes (pipelined: 18)
Feb 05, 2020 07:03:32.158 [0x7f128f302700] DEBUG - Completed: [192.168.1.70:52804] 200 GET /playlists?playlistType=audio%2Cvideo&sort=titleSort (16 live) GZIP 5ms 1056 bytes (pipelined: 3)
Feb 05, 2020 07:03:37.118 [0x7f12a6037700] DEBUG - Auth: authenticated user 1 as keyspd
Feb 05, 2020 07:03:37.119 [0x7f128ed26700] DEBUG - Request: [192.168.1.70:52803 (Subnet)] GET /:/timeline?bufferedTime=27&duration=54054&key=%2Flibrary%2Fmetadata%2F173160&location=lan&playQueueItemID=3414&playbackTime=1126&ratingKey=173160&state=paused&time=1067 (16 live) GZIP Signed-in Token (keyspd)
Feb 05, 2020 07:03:37.120 [0x7f128ed26700] DEBUG - Client [A3384CF1-DF2F-4F9C-8A63-71C900D018E3] reporting timeline state paused, progress of 1067/54054ms for guid=, ratingKey=173160 url=, key=/library/metadata/173160, containerKey=, metadataId=173160, source=
Feb 05, 2020 07:03:37.120 [0x7f128ed26700] DEBUG - [Now] User is keyspd (ID: 1)
Feb 05, 2020 07:03:37.121 [0x7f128ed26700] DEBUG - [Now] Device is iOS (Sid’s phone).
Feb 05, 2020 07:03:37.121 [0x7f128ed26700] DEBUG - [Now] Profile is iOS
Feb 05, 2020 07:03:37.121 [0x7f128ed26700] DEBUG - [Now] Updated play state for /library/metadata/173160.
Feb 05, 2020 07:03:37.121 [0x7f128ed26700] DEBUG - Statistics: (A3384CF1-DF2F-4F9C-8A63-71C900D018E3) Reporting active playback in state 1 of type 1 (scrobble: 0) for account 1
Feb 05, 2020 07:03:37.124 [0x7f12a6037700] DEBUG - Completed: [192.168.1.70:52803] 200 GET /:/timeline?bufferedTime=27&duration=54054&key=%2Flibrary%2Fmetadata%2F173160&location=lan&playQueueItemID=3414&playbackTime=1126&ratingKey=173160&state=paused&time=1067 (16 live) GZIP 6ms 492 bytes (pipelined: 19)
Feb 05, 2020 07:03:38.429 [0x7f12a6037700] DEBUG - Completed: [192.168.1.77:61631] 200 GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cmirror%2Cplayqueues&timeout=1 (16 live) GZIP 20000ms 5 bytes (pipelined: 1779)
Feb 05, 2020 07:03:38.436 [0x7f128f302700] DEBUG - Auth: authenticated user 1 as keyspd
Feb 05, 2020 07:03:38.437 [0x7f1221fc5700] DEBUG - Request: [192.168.1.77:61631 (Subnet)] GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cmirror%2Cplayqueues&timeout=1 (16 live) GZIP Signed-in Token (keyspd)
Feb 05, 2020 07:03:38.437 [0x7f1221fc5700] DEBUG - Content-Length is -1 (of total: -1).
Feb 05, 2020 07:03:40.205 [0x7f12a6037700] DEBUG - handleStreamWrite code 32: Broken pipe
Feb 05, 2020 07:03:40.205 [0x7f12a6037700] DEBUG - NotificationStream: Removing because of error
Feb 05, 2020 07:03:40.205 [0x7f12a6037700] DEBUG - Completed after connection close: [192.168.1.70:52796] 200 GET /:/eventsource/notifications (14 live) GZIP 60001ms 2941 bytes (pipelined: 1)
Feb 05, 2020 07:03:42.249 [0x7f12a6037700] DEBUG - Completed: [192.168.1.77:60556] 200 GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cmirror%2Cplayqueues&timeout=1 (13 live) GZIP 20000ms 5 bytes (pipelined: 1777)
Feb 05, 2020 07:03:42.255 [0x7f128f302700] DEBUG - Auth: authenticated user 1 as keyspd
Feb 05, 2020 07:03:42.256 [0x7f1223735700] DEBUG - Request: [192.168.1.77:60556 (Subnet)] GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cmirror%2Cplayqueues&timeout=1 (13 live) GZIP Signed-in Token (keyspd)
Feb 05, 2020 07:03:42.256 [0x7f1223735700] DEBUG - Content-Length is -1 (of total: -1).
Feb 05, 2020 07:03:58.437 [0x7f128f302700] DEBUG - Completed: [192.168.1.77:61631] 200 GET /p
It does sleep when not using it like any other iPhone, nothing out of the ordinary I would think.
Looks like I’m having similar issues (Syno 916+). Will try to grab logs asap.Plex Media Server Logs_2020-02-08_20-10-59.zip (13.1 MB)
added logs. had to do a restart to grab them.
@keyspd
If the phone goes to sleep when it’s syncing, bad things happen.
iOS doesn’t allow enough CPU time for the sync to complete.
it times out and flags the job failed.
Thanks for the logs.
I’m not seeing any overt errors in them.
What I paid extra attention to were the shorter -than-normal log files.
In all but one case, PMS had been commanded to shutdown. (signal 15)
The one case where it was not, it looked like DSM forced the shutdown which resulted in a ‘crash’.
Thanks; does this mean that if PMS is open/running on another device while the iPhone sleeps and PMS is syncing things should be okay? I noticed PMS not shutting off this weekend but I had PMS running on my laptop.
PMS runs on the server. The server runs constantly unless programmed to shutdown / startup by the system hosting it.
Each device is independent.
Ah, understood. So then it was stopping on the NAS/server then because I could not access it from my laptop or iPhone. Anyway, it’s been working okay for the past day or so. Thanks for your help.
Hey - so is there a solution for the iPhone app shutting down? Even if i restart the app it does not connect upon waking up.
Candidly? I don’t know . (I know I’m going to get chastized for saying it.) I’m not an app guy so I will have ask.
