That would hopefully work out! I have 2 SanDisk USB keys I bought for unraid a couple years before I built my system (an eternity ago.) One is in use with unRAID right now and never gave any fuss.
WD bought SanDisk (2016) – There was a change in MFG facilities
I cut open the other thumb drive which gave issues.
– It’s eMMC flash (which is fine here for READ-ONLY with a little writing
– The storage module is Samsung.
I bought 5 PNY USBs (64 GB) USB 3.0 for personal use.
I dedicated one for this effort.
I then, using my Mac Mini , created the drive.
I had to put the drive back into my workstation to make it BOOTABLE before I could actually use it. ( I think that can/should be improved and part of the USB creation )
I did learn – unraid USB creator on Win 10 Pro in VMWare workstation with USB passthrough == NO GO.
This has been a VERY frustrating task just to get to the point where I can properly support you all and find out what’s happening with Plex!!!
Fingers are now crossed that:
HDD in USB slot (yes I know but that’s all I have)
UNRAID thumb drive in “always on” USB slot.
I’ve loaded up my media library into PMS so we wait.
(NFS mounted via CA Scripts)
If there was an error found during the check, it would correct it. I looked at the main unRAID screen and it is set to correct parity if an error was found, and I am sure that it would be in the log if there was an error. No errors were found at all.
