PMS require SSL & PlexConnect?
Is it possible to get PlexConnect to work if the PMS >network>Require SSL is enabled? It doesn’t work for me if I enable it.
Yes, it should be ok.
Though some routers are giving trouble accessing a local PMS via “public” address string - which will be provided by myplex/plex.tv. Check for DNS-rebind-protection and a whitelist…
my router doesn’t support this but plexconnect works fine for non-ssl on plex server. Is there a plexconnect config to support ssl?
If you have a recent version, PlexConnect should be fine with or without SSL. As soon as your aTV (aka PlexConnect) plus your PMS are signed in to MyPlex, SSL should work.
Regarding DNS-rebinding there is no difference between SLL or not, provided you are signed in.
