PlexConnect aTV2 PMS 1.14.1.5488 No Libary
I updated my pms and now my plexconnect wont connect libaries, The only thing that changed was the pms Jail on my freenas was updated.
I finally got it to work If a disabled the secure connections on the PMS settings > Network > Prefered to disabled. but I would like to not have that disabled.
The setup that worked was set the pms ip and autodetect to false in the plexconnect settings.cfg then login on the atv2 then discover the pms and then everything shows ok.
if I log off the server (unclaimed) then it works with the security setting to preffered.
Any help on this issue would be great.
Probably Q7 in PlexConnect FAQ has the solution for your problem.
it was the rebinding issue in my firewall, i just could understand how it was related until i ran the plex connect services in the forground and saw the running log and all the dns/pms ip address and server found not found.
works perfectly now
