PMS shuts down every night during scheduled maintenance after using download/sync
Server Version#: 1.24.5.5173 (And Previous version)
Player Version#: N/A
On Oct 31 I used download (remote download) for the first time in a while. PMS shutdown and manually restarted. Every night sense, a few minutes after scheduled nightly maintenance , the PMS shuts down. Any ideas if there are stuck activity that could be manually cleaned up?
Example of the typically last Log:
Plex Tuner Service.log -
Nov 17, 2021 02:05:25.996 [0x80307b000] DEBUG - Parent process no longer present; exiting
Nov 17, 2021 02:05:26.153 [0x80307b000] INFO - [I] device_manager_t::term
Nov 17, 2021 02:05:26.153 [0x80307b000] INFO - [I] device_manager_t::term. Stop all devices
Nov 17, 2021 02:05:26.179 [0x80307b000] INFO - [I] device_manager_t::term. Shut down all device auxes
Nov 17, 2021 02:05:27.448 [0x80307b000] INFO - [I] web_server_t::stop. Web server is stopped
Nov 17, 2021 02:05:27.448 [0x80307b000] INFO - [I] device_manager_t::term
Nov 17, 2021 02:05:27.448 [0x80307b000] INFO - [I] device_manager_t::term. Stop all devices
Nov 17, 2021 02:05:27.448 [0x80307b000] INFO - [I] device_manager_t::term. Shut down all device auxes
Nov 17, 2021 02:05:27.448 [0x80307b000] INFO - [I] broker_t::shutdown. Shutdown is completed
I am having the same issue periodically on my Synology
edit.
I am on PMS Version 1.24.5.5173
DSM 7.0-41890
I found my issue. The downloads was a coincidence. Turned out to be a bad video file. PMS would use all all the memory and then would get shutdown. The logfiles were not very descriptive on which file was causing the problem (could have been a couple, just deleted a whole directory to be safe). Also seams like a bug that a bad video file would lead to such a large memory leak.
