PMS SSL Uses *.plex.direct Let's Encrypt SSL certificate instead of custom configured certificate
Server Version#: 1.32.0.6918
Player Version#: N/A (web 4.100.1)
I have PMS configured with a SSL custom certificate. Having just upgraded to 1.32.0.6918, instead of the custom certificate, PMS serves a Let’s Encrypt certificate on CN: *..plex.direct. I can reproduce on two different servers.
The custom SSL certificate is configured in Settings → Network. The PMS configuration is unchanged before and after the upgrade.
% echo | openssl s_client -showcerts -servername <server name> -connect <server name>:32400
CONNECTED(00000005)
depth=2 C = US, O = Internet Security Research Group, CN = ISRG Root X1
verify return:1
depth=1 C = US, O = Let's Encrypt, CN = R3
verify return:1
depth=0 CN = *.<removed>.plex.direct
verify return:1
write W BLOCK
Certificate chain
0 s:/CN=*.<removed>.plex.direct
i:/C=US/O=Let's Encrypt/CN=R3
-----BEGIN CERTIFICATE----
MIIFYTCCBEmgAwIBAgISBMxMaXqo7EGOIuD/IZ9ZbtlhMA0GCSqGSIb3DQEBCwUA
nLRbwHOoq7hHwg==
-----END CERTIFICATE-----
2 s:/C=US/O=Internet Security Research Group/CN=ISRG Root X1
i:/O=Digital Signature Trust Co./CN=DST Root CA X3
-----BEGIN CERTIFICATE-----
MIIFYDCCBEigAwIBAgIQQAF3ITfU6UK47naqPGQKtzANBgkqhkiG9w0BAQsFADA/
Dfvp7OOGAN6dEOM4+qR9sdjoSYKEBpsr6GtPAQw4dy753ec5
Server certificate
subject=/CN=*.<removed>.plex.direct
issuer=/C=US/O=Let's Encrypt/CN=R3
No client certificate CA names sent
Server Temp Key: ECDH, X25519, 253 bits
SSL handshake has read 4617 bytes and written 374 bytes
New, TLSv1/SSLv3, Cipher is AEAD-CHACHA20-POLY1305-SHA256
Server public key is 2048 bit
Secure Renegotiation IS NOT supported
Compression: NONE
Expansion: NONE
No ALPN negotiated
SSL-Session:
Protocol : TLSv1.3
Cipher : AEAD-CHACHA20-POLY1305-SHA256
Session-ID:
Session-ID-ctx:
Master-Key:
Start Time: 1681395799
Timeout : 7200 (sec)
Verify return code: 0 (ok)
DONE
Likely caused by PMS’s switch to OpenSSL v3, which dropped support for some less secure encryption methods: OpenSSL v3.0.0 and PMS
Confirmed to be working, generating the pkcs12 file with -certpbe AES-256-CBC -keypbe AES-256-CBC -macalg SHA256 resolved the issue.
I am using win-acme to generate my own custom Let’s Encrypt certificate and I am seeing this same problem after upgrading my server. Are there any settings changes in win-acme for us Windows users that will produce a compatible certificate?
@aroberts02
Do you see where you posted and what’s above you?
I do see that there is a nice solution for those using openssl, but I am using win-acme and was hoping that the team had anticipated issues like this coming up after the upgrade.
Custom certs are not required for normal PMS use.
Therefore, if users want to add them then they must understand how to create and manage them.
For anyone out there using win-acme to generate custom certs, win-acme does not provide built-in options to customize the encryption and MAC algorithms used within a PFX archive file. Instead, you will have to request a Let’s Encrypt certificate with options that result in the creation of PEM-formatted certificates, which will give you full chain {hostname}-chain.pem and private key {hostname}-key.pem files. In a post-processing script, convert the PEM-formatted certificate and private key to a PFX file using the specified encryption and MAC algorithms: openssl pkcs12 -export -in {hostname}-chain.pem -inkey {hostname}-key.pem -out cert_and_key.pfx -certpbe AES-256-CBC -keypbe AES-256-CBC -macalg SHA256 -password pass:your_password
Well I used the above fix to repackage my cert and everything was fine. Until I installed Version 1.32.5.7210 on my Synology and now its back to using a lets encrypt cert. So what changed now? did they decide all those keytool commands weren’t enough I need more now.
And don’t give me its not required for normal use bull feces. So if you patched and it went back to using lets encrypt instead of you named certificate then upvote this so maybe plex will look at it. otherwise I will just have to click past half a dozen errors and warnings to get to plex.
I’m trying to do this with a newly spun up plex instance in a docker container. I mounted a volume called config in which I put my p12 certs. I did generate my cert using the improved encryption schemes. I chmod 755 the p12 file. I told plex where to find my file and entered its passphrase. Still, Plex refuses to use my cert.
Is there anything special about running plex in a docker container that would prevent it for using my cert?
Thanks,
A few key points about PMS and custom certs:
  1. Self-signed certs cannot be used
  2. Cert files (P12) must include the CA with the Key and Cert
  3. P12 files must now use the stronger encryption
Reference:
