PMS Suddenly Not Accessible From Certain Devices
@crawpappy However, only the web player is affected, right? So this clearly is an issue with the web player and not with the server, so I am sorry, but I cannot help you with the issue right now. The web player forum is really crowded right now as it appears there are multiple unresolved bugs, so good luck.
Personally, I strongly advise you to use the native iOS client. It requires significantly less transcoding and is significantly faster, as the mobile browsers have an even more limited codec support than the apps on iOS :slight_smile:
Thank you for the input and all the work on Plex for RPi.
