PMS unable to detect changes to FUSE mounted drives
PMS Version 1.18.3.2156.
As the title states, I’m using a FUSE-based mount for my PMS which utilizes rclone as the backend.
I’m noticing that changes are not being detected when new files are being added and library is not being updated.
Is this a known issue or an inherent limitation of FUSE drives?
Above, AFAIK
Ref: Fsnotify and FUSE · libfuse/libfuse Wiki · GitHub
Is fsnotify a framework Plex uses for detection of files?
AFAIK, yes
So the only option is to stick to auto-scanning at intervals?
That, and manual refresh, or some scripting.
(Also, AFAIK, Sonarr and Radarr also does a refresh, if configured correctly, if you use those)
Unfortunately, Radarr and Sonarr run on a Digital Ocean droplet, but the PMS runs on a RPi 4 at home. You see I have bad peering and there’s also the issue of CGNAT :slight_smile:
another option is Plex_Autoscan
Script to assist sonarr/radarr with plex imports. Will only scan the folder that has been imported, instead of the whole library section. - l3uddz/plex_autoscan
Plex Autoscan is a python script that assists in the importing of Sonarr, Radarr, and Lidarr downloads into Plex Media Server.
It does this by creating a web server to accept webhook requests from these apps, and in turn, sends a scan request to Plex. Plex will then only scan the parent folder (i.e. season folder for TV shows, movie folder for movies, and album folders for music) of the media file (versus scanning the entire library folder).
In addition to the above, Plex Autoscan can also monitor Google Drive for updates. When a new file is detected, it is checked against the Plex database and if this file is missing, a new scan request is sent to Plex
So you can either have Sonarr/Radarr send the notice or just have PAS monitor GDrive
Not an option:
