Just upgraded and looks like my server is no longer supporting transcoding hardware acceleration. Anyone else seeing the same thing or is my config broken?
edit:
To clarify, the option is still there in the settings but it doesn’t seem to do anything.
Do you run your PMS on a Synology? If yes, try deinstall and reinstall this could fix it. Your Library will be untouched.
I’m on Ubuntu 16.04 server if it makes a difference.
Found some errors in the logs as well:
Feb 01, 2018 11:53:17.887 [0x7f296c7fd700] DEBUG - Codecs: testing h264_nvenc (encoder)
Feb 01, 2018 11:53:17.887 [0x7f296c7fd700] ERROR - [FFMPEG] - Cannot load libcuda.so.1
Feb 01, 2018 11:53:17.887 [0x7f296c7fd700] WARN - avcodec_open2 returned -1313558101 for encoder ‘h264_nvenc’
Feb 01, 2018 11:53:17.887 [0x7f296c7fd700] DEBUG - Codecs: hardware transcoding: testing API vaapi
Feb 01, 2018 11:53:17.887 [0x7f296c7fd700] ERROR - [FFMPEG] - No VA display found for device: /dev/dri/renderD128.
Sorry, still new to PMS, does this make sense to anyone?
Reinstalled and rebooted and things are back to normal. Just bad luck perhaps.
