Server Version#:1.14.1.5488
Player Version#:1.14.1.5488
For some reason, when I play HEVC files from my plex server, the playback quality is horrible on my pc. It looks like it was scaled down to 480p. Both systems can handle HEVC no problem and everything is set to max quality. Is there any known reason why this happens?
If it matters I’m running a vmware ESXI host system with Freenas and Windows Server 2016. Windows server is the plex host as I couldn’t get plex to work after a week or 2 of troubleshooting running directly in Freenas.
Playing in a web browser will always transcode HEVC content.
If your server is running in a virtualized environment, check whether you have direct network access from client to server or if the connection is ‘indirect’, which means the bitrate is limited to 2mbps.
Hm, OK the file was Direct Play’ed by PMP, so the server has no influence over the visual quality.
We must now continue the investigation on the side of the Player.
Which type of graphics adapter (GPU) is in the machine?
A log file from the Plex Media Player after this file has been played would be useful. https://support.plex.tv/articles/207338748-plex-media-player-logs/
Huh, looks like turning on OpenGL fixed the issue. I would have never thought I would have to go into tv mode to fix an issue like that. I was kinda worried I would have to stay in tv mode, but it seems the settings transferred over to the standard PMP.
