I had some users on Plex that I removed perhaps a month ago. Once deleted from both Home and Sharing users, the statistics were gone as well (as they should be).
Unfortunately, I had afterwards an issue with one of my Data HDD’s, that I had to replace. I did not replace the main system HDD where Plex is installed.
After replacing the Data HDD, the old users are now back under the statistics menu? Why is that?
You can change the view to last 7 days or another time frame, but for “all time” they will show up unless you go into the database manually to remove them. ( Which i understand not wanting to do)
True that it does not show removed movies but it does not remove the history that a movie was watched. If you re-add a movie later on ( even years later) it will still know that movie was watched (based on GUID) and it will not have the orange triangle in the corner of poster
Ok. This is very frustrating though. I would hope you would consider letting plex just delete all the data from deleted users. There is a reason why they are deleted.
