I had the default one PlexComskip came but it wasnt as good as the one I found on the comskip country INI forums (grabbed one for USA OTA.) I get the same results executing through plex post processing using the default or this one.
root@torrentbox:~# cat /usr/local/scripts/PlexComskip/comskip.ini
; See comskip.txt in the distribution zip file for many settable parameters, read manual.html, tuning.html and debugwindow.html for how to tune and debug comskip
detect_method=107 ; 1=black frame, 2=logo, 4=scene change, 8=fuzzy logic, 16=closed captions, 32=aspect ration, 64=silence, 128=cutscenes, 255=all
validate_silence=1 ; Default, set to 0 to force using this clues if selected above.
validate_uniform=1 ; Default, set to 0 to force using this clues (like pure white frames) if blackframe is selected above.
validate_scenechange=1 ; Default, set to 0 to force using this clues if selected above.
verbose=1 ; Show a lot of extra info, level 5 is also OK, set to 0 to disable
max_brightness=60 ; Frame not black if any pixels checked are greater than this (scale 0 to 255)
test_brightness=40 ; Frame not pure black if any pixels checked are greater than this, will check average brightness (scale 0 to 255)
max_avg_brightness=25 ; Maximum average brightness for a dim frame to be considered black (scale 0 to 255) 0 means autosetting
maxbright=1 ; New
brightness_jump=200 ; New
max_commercialbreak=600 ; Maximum length in seconds to consider a segment a commercial break
min_commercialbreak=21 ; Minimum length in seconds to consider a segment a commercial break, some sports require lower numbers than normal tv shows
max_commercial_size=125 ; Maximum time in seconds for a single commercial or multiple commercials if no breaks in between
min_commercial_size=4 ; Mimimum time in seconds for a single commercial
min_show_segment_length=126 ; Any segment longer than this will be scored towards show (sports and 30 minute programming), increase this to 250 for 1 hour long programming
non_uniformity=500 ; Set to 0 to disable cutpoints based on uniform frames
max_volume=500 ; Any frame with sound volume larger than this will not be regarded as black frame
max_silence=100 ;
min_silence=12 ; Any deep silence longer than this amount of frames is a possible cutpoint
noise_level=5 ; New
ticker_tape=0 ; Amount of pixels from bottom to ignore in all processing
ignore_side=0 ; New, default 0
subtitles=0 ; New, default 0
logo_at_bottom=0 ; Set to 1 to search only for logo at the lower half of the video, do not combine with subtitle setting
use_existing_logo_file=1 ; Use logo file already created at beginning of show, default 0
two_pass_logo=1 ; New
punish=0 ; Compare to average for sum of 1=brightness, 2=uniform 4=volume, 8=silence, 16=schange, set to 0 to disable
punish_threshold=1.3 ; Multiply when amount is above average punish_threshold
punish_modifier=2 ; When above average * threshold multiply score by this value
intelligent_brightness=0 ; Set to 1 to use a USA specific algorithm to tune some of the settings, not advised outside the USA
logo_percentile=0.92 ; If more then this amount of logo is found then logo detection will be disabled
logo_threshold=0.75 ; Digital signals can be higher
min_black_frames_for_break=1 ;
punish_no_logo=1 ; Default, set to 0 to avoid show segments without logo to be scored towards commercial
aggressive_logo_rejection=0
connect_blocks_with_logo=1 ; Set to 1 if you want successive blocks with logo on the transition to be regarded as connected, set to 0 to disable
delay_logo_search=0 ;
logo_filter=2 ; Set the size of the filter to apply to bad logo detection, 4 seems to be a good value
edge_step=2 ; New, default 1
cut_on_ar_change=1 ; Set to 1 if you want to cut also on aspect ratio changes when logo is present, set to 2 to force cuts on aspect ratio changes. set to 0 to disable
delete_show_after_last_commercial=0 ; Set to 1 if you want to delete the last block if its a show and after a commercial
delete_show_before_first_commercial=0 ; New, default 0
delete_show_before_or_after_current=0 ; Set to 1 if you want to delete the previous and the next show in the recording, this can lead to the deletion of trailers of next show
delete_block_after_commercial=0 ; Set to max size of block in seconds to be discarded, set to 0 to disable
remove_before=0 ; Amount of seconds of show to be removed before ALL commercials
remove_after=0 ; Amount of seconds of show to be removed after ALL commercials
shrink_logo=5 ; Reduce the duration of the logo with this amount of seconds
after_logo=0 ; Set to number of seconds after logo disappears comskip should start to search for silence to insert an additional cutpoint
padding=1.5
ms_audio_delay=5
volume_slip=40
skip_b_frames=0 ; Set to 1 to force Comskip to skip frames for higher processing speed.
hardware_decode=0 ; Set to 1 to enable hardware accelerated video decoding, only available in donator version
thread_count=4 ; Set to utilize Quad Core
max_repair_size=200 ; Will repair maximum 200 missing MPEG frames in the timeline, set to 0 to disable repairing for players that don't use PTS
disable_heuristics=4 ; Bit pattern for disabling heuristics, adding 1 disables heristics 1, adding 2 disables heristics 2, adding 4 disables heristics 3, 255 disables all heuristics
delete_logo_file=1 ; Set to 1 if you want comskip to tidy up after finishing
output_framearray=0 ; Create a big excel file for detailed analysis, set to 0 to disable
output_data=0 ; Create a dump of the user data channel, used for CC and XDS (such as V-Chip info). Can be use together with output_framearray to remote debug CC decoding
output_videoredo=0 ; The old videoredo format
output_videoredo3=0 ; The new videoredo v3 format
output_womble=0
output_mls=0 ; Set to 1 if you want MPEG Video Wizard bookmark file output
output_cuttermaran=0
output_mpeg2schnitt=0
output_mpgtx=0
output_dvrcut=0
output_zoomplayer_chapter=0
output_zoomplayer_cutlist=0
output_edl=1
output_dvrmstb=0 ; Set to 1 if you're running DVRMS-Toolbox
output_edlx=0
output_vcf=0
output_bsplayer=0
output_btv=0 ; Set to 1 if you want Beyond TV chapter cutlist output
output_projectx=0 ; Set to 1 if you want ProjectX cutlist output (Xcl)
output_avisynth=0
output_vdr=0 ; Set to 1 if you want XBMC to skipping commercials
output_demux=0 ; Set to 1 if you want comskip to demux the mpeg file while scanning
sage_framenumber_bug=0
sage_minute_bug=0
live_tv=1 ; Set to 1 if you use parallelprocessing and need the output while recording
live_tv_retries=2 ; Change to 16 when using live_tv in BTV, used for mpeg PS and TS
dvrms_live_tv_retries=300 ; Only used for dvr_ms
standoff=0 ; Change to 8000000 when using live_tv in BTV
cuttermaran_options="cut=\"true\" unattended=\"true\" muxResult=\"false\" snapToCutPoints=\"true\" closeApp=\"true\""
mpeg2schnitt_options="mpeg2schnitt.exe /S /E /R25 /Z %2 %1"
avisynth_options="LoadPlugin(\"MPEG2Dec3.dll\")
MPEG2Source(\"%s\")
dvrcut_options="dvrcut \"%s.dvr-ms\" \"%s_clean.dvr-ms\" "
windowtitle="Comskip - %s"
