PowerShell 4.0: Using Plex REST APIs
Hi all,
I've been playing around with the Plex API's using the Invoke-RestMethod cmdlet and the unofficial document around the APIs.
Posting the below to help out others, the code will:
  1. Get a auth token using supplied credentials
  2. Connect to a local Plex Media Server
  3. Get a list of libraries
This list then can be iterated over for a variety of purposes. I'm currently working with it to get a list of duplicate files, pick the best quality one and remove the others for a cleanup of recently mass imported data.
Feel free to post criticisms, feedback and other useful tips!
Mileage may vary, use at own risk, requires PowerShell 4.0+
#'Get Credentials, convert to Base64 for basic HTML Authentication
[string]$command = "Get-credential"
Try
    $cred           = Get-Credential
    $base64AuthInfo = [Convert]::ToBase64String([Text.Encoding]::ASCII.GetBytes(("{0}:{1}" -f $cred.GetNetworkCredential().UserName,$cred.GetNetworkCredential().Password)))
catch
    break;
#'Invoke REST API
[string]$command = "Invoke-RestMethod -Uri ""https://plex.tv/users/sign_in.xml""-Method POST -headers   @{'Authorization'=(""Basic {0}"" -f $base64AuthInfo);'X-Plex-Client-Identifier'=""TestApp"";'X-Plex-Product'=""TestScript"";'X-Plex-Version'=""V1.00"";'X-Plex-Username'=$cred.GetNetworkCredential().UserName;}"
Try
    [array]$data =  Invoke-RestMethod `
                    -Uri "https://plex.tv/users/sign_in.xml"`
                    -Method POST `
                    -headers   @{
                                    'Authorization'=("Basic {0}" -f $base64AuthInfo);
                                    'X-Plex-Client-Identifier'="PowerShell-Test";
                                    'X-Plex-Product'='PowerShell-Test';
                                    'X-Plex-Version'="V0.01";
    $authToken   = $data.user.authenticationToken
    "Executed: $command"
catch
    "Executing: $command"
    break;
[string]$localPlexAddr    = "10.0.0.6"
[string]$plexRESTAddr   = "library/sections"
#'Invoke REST API
[string]$command = "Invoke-RestMethod -Uri ""http://$localPlexAddr`:32400/$plexRESTAddr"" -Method POST -headers   @{'Authorization'=(""Basic {0}"" -f $base64AuthInfo);'X-Plex-Client-Identifier'=""TestApp"";'X-Plex-Product'=""TestScript"";'X-Plex-Version'=""V1.00"";'X-Plex-Username'=$cred.GetNetworkCredential().UserName;'X-Plex-Token'=$authToken}"
Try
    [array]$data =  Invoke-WebRequest `
                    -Uri "http://$localPlexAddr`:32400/$plexRESTAddr" `
                    -Method GET `
                    -Headers   @{
catch
    break;
[xml]$apiContent         = $data.Content
[array]$plexLibraries   = $apiContent.MediaContainer.Directory
Great work Robert, thanks for sharing!  B)
