Pre-Roll Feature Separation
I would like to request 'Pre-Roll Feature Separation' where you have a choice of playing the pre-roll without having to play trailers as well in all the apps and web.
thanks!
Set Trailers to Zero, only the Pre-Roll will play if enabled.
No that only works on Android. Not on anything else I think.
Incorrect. It works on all my various devices that can view a preroll, including the Roku Pre-Release, and in Plex/Web as well. ;)
Just tried iOS and it does not work.
