Premium Music Library
How about setting the "badge image" to the left of the duration (), but with some space in between? Would that be possible? With this, it wouldn't push the title to the right, the duration would be aligned right and the badges just sitting in between...
It is totally possible that you found another bug in there... but as you know, unfortunately Apple didn't want to hear about it from our side. :-(
Unfortunately you're really limited as to what you can do with images and accessories in a menu item, the image is always the first thing on the left of the menu item and any accessories are always the last thing on the far right of the menu item :( So unfortunately you can't put the "badge" to the left of the :(
Just a quick question here - has the new premium music feature for the Apple Tv being resolved ?
Many thanks
Many thanks
Not sure what you're asking.... Has what been resolved?
I believe he was asking if the Premium Music libraries have been fully implemented yet in PlexConnect. To my knowledge it works fine.
Apologies Rock Star, Ostledev is correct - thats what I was asking as it is not working for me !
Do I need to update something to cope with this extra option ?
Thanks again
You need the latest PMS, the latest PlexConnect and a PlexPass subscription. If it doesn’t work after that then you need to post the required information:-
How To Report An Issue
This is amazing :) I think you can call the current version 0.6!
Is there any chance that you could expose the "Moods" functionality?
Ok, many thanks for that roidy. I have the PlexPass and have the up to date PMS on my NAS - so just need to check on the version of PlexConnect I have and I believe tomer1749 says that the up to date version is 0.6 - so will compare !
Many thanks again.
NJP
That's not what tomer1749 said.
On the Settings screen we now have a "Commit Date" that shows when the version you're using was created. If you don't see this then you're using an old version:-
![post-51394-0-83029300-1432312711.jpg|600x298](upload://nd0PgHCMI5LTYCpSlnSmedtPS2Q.jpg)
I'm working on it :)
Great!
