Server Version#: Version 1.32.1.6999
Player Version#: 1.67.2.3705-db506a00
Hello all!
I’ve migrated my Plex server installation from a RP4 with docker to a Windows 11 Pro X64 computer.
I’ve copied the app data from the source to the destination and my media library folder is that same because I was using a NTFS drive that I also moved.
I’m facing some problems scanning my TV Show library. At first, just a few would correctly show. I’ve deleted the library DB and now a lot of them show. There are a couple that show with as they were deleted but I can still play those episodes, but the new ones from that show that were added after the install don’t even show. I’ve deleted those media and readded them but without any success. Last test that I did was to delete the shows from the library collection and re-add them. Now I can’t see them back.
How can i fix this?
Thanks in advance
