Problem by casting with chromecast
Hello!
It’s the first time I have problems with plex… I like it and I choose a bose speaker 500 with chromecast builtin for streaming plex-music.
I received the speaker today and I tried it out. It doesn’t work. I can start casting, the music starts on the speaker using chromecast, but after 10 seconds, the music stutters, starting and starting again. It doesn’t work. I tryed with different android devices and made several factory resets of the speaker, tryed changing wlan connection…
After three hours trying, I decided to write this post.
Did anybody have the same problem or an idea who to solve the problem?
Thanks in advance,
Best regards,
Stephan
Same problem here on all my Bose Speakers
Chromecast works if I use a different player from the same source and network setup. Seems to be a Plex problem ongoing for a few months.
Hello. Yes, I tried Hifi Cast and activated dlna on the plexserver: it works fine. The only problem, all is now open in my network, because dlna ist activated.
I saw in the Bose support page, that Bose doesn’t support video chromecast. I suppose that plex cast music with a video-stream (showing the track and all). That should be deactivated for working with Bose…
I’ve just tested symfonium (https://play.google.com/store/apps/details?id=app.symfonik.music.player&hl=de&gl=US). It works very well and uses PLEX directly, without activating dlna.
I will check it out. Thanks.
