Problem TV4HD Sweden Free DVB-T, Error
Cant stream TV4HD only get error, cant navigete to the server.
All other channels work.
When I use hauppauge WinTV on same PC i can watch TV4HD in the software.
Anyone know why?
Are there any config file I can access to see that the frequencies is set correct?
Tried two diffrent Hauppauge driver versions, same problem.
Server Version#: 1.24.5.5173
Player Version#: 1.37.0.2706-5b2cfe50, Shield, Androidphone
Tuner Make/Model: WinTV-quadHD
Guide/Lineup name: Boxer Antenn
Using XMLTV?: No
Channel number/Name: 004 TV4HD
Have the same problem. Have a HDHomerun Quattro. Tried both TV4SWED and TV4HD with no luck. Very strange behavior since I can see the channel through the HDHomeriun app.
With Server update to
Server Version#: 1.25.0.5282
It is working.
Will test it some more see if it holds up.
Can you confirm bjornfj!?
Confirmed, works perfect with 1.25
Thanks!
