Problem when upgrading to PlexConnect 0.5-6 (And PConnect 0.5-1 OK)
Hi Folks,
I'm under DSM 5.1-5021 Update 2 (Syno412+) and the latest PMS PlexMediaServer-0.9.11.7.803-87d0708-x86.spk which both work well.
The problem I have is with the Apple TV 3 connection. When I use the latest Plexconnect 0.5-6 the apple TV is not able to create the Profile (trying to create the profile "Trailer url etc ... - I get the error message code 107 if I remember well, URL not valid ....).
However, when I downgrade to plexconnect 0.5-1, it works, the profile can be created and everything is all right ! :)
I noticed that Plexconnect 0.5-1 is formally requesting the NAS IP and DNS during the installation process, and not plexconnect 0.5-6.
My question is - what specific parameter should be set to enable PC 0.5-6 to work with the ATV3?
(I tried many things, stop/restart PConnect PMS my rooter etc ... but the latest PConnect is never working)
If the cert does not change the you don’t need to load the profile again. Also I suggest you raise this on the synology thread as the package creator has made many comments on this issue recently (Infact you might find the answer already in that thread).
I tried to reload the profile because the ATV3 was not responding anymore with the latest PConnect. I already posted a message in the Synology forum who invited me to post a message here as well. It looks like the problem I'm referring to is not so frequent.
This is the Synology thread for PlexConnect (I saw your other post on the Synology Plex Server, which is a different thing).
