Bonjour,
Here is the log file with debug mode enabled… I did only enable the debug mode not the verbose… hope it’s OK…
I Do have few questions regarding the contains of the log file…
1 – line 37 : Dec 08, 2021 05:56:24.506 [7968] WARN - Couldn’t determine bundle identifier for plug-in at: “C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-34f965be8\WebClient.bundle”
I tried to fix it, but was unable… have you an idea of where should I look for to fix it…
2 – line 187 : I seem to ping my IPAD, but my IPAD was idle and no session was active and the Plex APPS is not even started on it… It try a lot to talk to it has seen in the log… strange… May be it’s OK…
3 – line 303 : Dec 08, 2021 05:56:27.213 [19224] WARN - [DatabaseFixups] Held transaction for too long (…\Library\MetadataCollection.cpp:479): 0.109375 seconds
Dec 08, 2021 05:56:27.214 [19224] DEBUG - [DatabaseFixups] Collections: Refreshed attributes for 0 collections in section 1 in 60ms.
Dec 08, 2021 05:56:27.214 [7968] WARN - Took too long (0.109375 seconds) to start a transaction on …\Plugins\PluginDatabaseState.cpp:189
Dec 08, 2021 05:56:27.214 [7968] WARN - Transaction that was running was started on thread 19224 at …\Library\MetadataCollection.cpp:306
This is a fast machine, but not the fastest
… but I do not understand why Plex complains as it is too long… I’m trying to figure that out but with no success…
4 – line 442 : Dec 08, 2021 05:56:28.689 [23380] WARN - HTTP error requesting GET http://192.168.1.99:34400/discover.json (7, Couldn’t connect to server) (Failed to connect to 192.168.1.99 port 34400: Connection refused)
Dec 08, 2021 05:56:28.690 [23380] ERROR - DVR:Device: Error refreshing existing device device://tv.plex.grabbers.hdhomerun/2019-10-3HA4-L7O76A, marking as dead.
Dec 08, 2021 05:56:28.690 [23380] DEBUG - DVR:Device: Testing grabber HDHomerun device device://tv.plex.grabbers.hdhomerun/2019-10-3HA4-L7O76A:10 at http://192.168.1.99:34400
Dec 08, 2021 05:56:28.690 [23380] DEBUG - DVR:Device: Device device://tv.plex.grabbers.hdhomerun/2019-10-3HA4-L7O76A:10 was already known, refreshing database info
It seem trying to connect using port number 34400 — but there is no such a port number – this is not what is indicated in the configuration of the server! why did he stuck on this port number all along in the log file…?
5 – line 745 : Dec 08, 2021 05:56:36.929 [23332] DEBUG - Activity: registered new activity ff7de815-a638-4c95-be53-71eeffa5f081 - “Refreshing Sub”
Dec 08, 2021 05:56:36.930 [8220] ERROR - PlexClient::downloadContainer: expected MediaContainer element, found html
Dec 08, 2021 05:56:36.930 [8220] WARN - Subscription: No container available for /tv.plex.providers.epg.cloud:173/metadata/plex%3A%2F%2Fshow%2F5fc6982c6a2ae8002d056729
Dec 08, 2021 05:56:36.930 [8220] ERROR - Subscription: Error refreshing sub: No container found
This type of errors happen often… is this really an error… how could I fix it… don’t even know where to look for…
I fall on those errors while I was investigating problem with tuners and errors in the transcoding process… those are related to latest release(5286)… and I try to have a clean installation before reporting the problem that I have with transcoding…
Thank you for your help…
Have a nice day…
PS: My apologies for my poor English, This is not my native language.
Denys.
Plex Media Server.zip (67.8 KB)
