Problem with playback on some files
New user here…
Just starting using Plex on WD PR4100 and testing it out.
I am using the latest beta Plex server from September 5.
I have quite a lot of media files (old black and white tv) which just play as a green square, both on the server preview and on the client, here is some info.
I did try remuxing with mkvtoolnix but this didn’t help, so I think it’s definitely the video, not the mkv container
Here’s a bit info. What should I do now? Thanks in advance.
PS I should say that these files play fine with other players, vlc etc. In fact I can stream them fine to my iphone using mycloud and vlc, for example.
Otherwise Plex is working fine.
Format : Matroska
Format version : Version 2
File size : 2.23 GiB
Duration : 47 min 22 s
Overall bit rate mode : Variable
Overall bit rate : 6 743 kb/s
Encoded date : UTC 2017-01-03 19:21:57
Writing application : MakeMKV v1.10.4 win(x86-release)
Writing library : libmakemkv v1.10.4 (1.3.3/1.4.4) win(x86-release)
ID in the original source medium : 224 (0xE0)
Format : MPEG Video
Format profile : Main@Main
Format settings : BVOP
Format settings, BVOP : Yes
Format settings, Matrix : Default
Format settings, GOP : M=3, N=10
Format settings, picture structure : Field
Codec ID : V_MPEG2
Codec ID/Info : MPEG 1 or 2 Video
Bit rate mode : Variable
Bit rate : 6 546 kb/s
Maximum bit rate : 9 000 kb/s
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 25.000 FPS
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.631
Time code of first frame : 00:59:59:00
Time code source : Group of pictures header
GOP, Open/Closed : Open
Stream size : 2.17 GiB (97%)
Language : English
Default : No
Forced : No
Color primaries : BT.601 PAL
Transfer characteristics : BT.470 System B/G
Matrix coefficients : BT.470 System B/G
