Problem with Twilight Zone
Hello! I have a problem with new Twilight Zone episodes.
Basically, they are managed by Plex as alternative versions of classic series ones.
So new 2019 episode 1x01 “The Comedian” is seen as alternative version of classic 1965 1x01 episode “Where is Everybody?”
How can I solve this? Here’s what I see in Media Info.
File
Elimina i file* U:\Incoming\Serie TV\The Twilight Zone (2019)\Season 1\1x01 The Comedian.mkv
Elimina i file* U:\Incoming\Serie TV\The Twilight Zone\Season 1\1x01 Where Is Everybody.mkv
Media
  • Durata 55:30
  • Bitrate 7160 kbps
  • Width 1920
  • Height 1080
  • Aspect Ratio 1.78
  • Video Resolution 1080p
  • Container MKV
  • Video Frame Rate 24p
  • Video Profile high
Parte
  • Durata 55:30
  • File 1x01 The Comedian.mkv
  • Size 2.78 GB
  • Container MKV
  • Codec H264
  • Bitrate 6520 kbps
  • Bit Depth 8
  • Chroma Location left
  • Chroma Subsampling 4:2:0
  • Color Primaries bt709
  • Color Range tv
  • Color Space bt709
  • Color Trc bt709
  • Frame Rate 24 fps
  • Height 1080
  • Livello 4.0
  • Profile high
  • Ref Frames 4
  • Scan Type progressive
  • Width 1920
  • Display Title 1080p (H.264)
  • Codec EAC3
  • Canali 6
  • Bitrate 640 kbps
  • Lingua English
  • Audio Channel Layout 5.1(side)
  • Sampling Rate 48000 Hz
  • Display Title English (EAC3 5.1)
  • Codec SRT
  • Lingua English
  • Titolo SDH
  • Display Title English (SRT)
Media
  • Durata 25:55
  • Bitrate 6028 kbps
  • Width 960
  • Height 720
  • Aspect Ratio 1.33
  • Video Resolution 720p
  • Container MKV
Parte
  • Durata 25:55
  • File 1x01 Where Is Everybody.mkv
  • Size 1.09 GB
  • Container MKV
  • Codec H264
  • Bitrate 5388 kbps
  • Lingua English
  • Bit Depth 8
  • Frame Rate 23.976 fps
  • Height 720
  • Livello 4.1
  • Profile high
  • Ref Frames 5
  • Width 960
  • Display Title 720p (H.264)
  • Codec AC3
  • Canali 2
  • Bitrate 640 kbps
  • Audio Channel Layout stereo
  • Display Title Sconosciuto (AC3 Stereo)
Thank you!
I used the following naming and Plex added the series with no problems.
/TV Shows
/The Twilight Zone (2019)
/Season 01
The Twilight Zone (2019) - s01e01 - The Comedian.mp4
The Twilight Zone (2019) - s01e02 - Nightmare at 30,000 Feet.mp4
