Problems finding media location (app and data on seperate drives)
Here’s a little background info. I just got a Beelink ME mini. It came with a 64GB eMMC and I’ve installed 2x 2TB SSDs. I installed ZimaOS, and created a RAID 1 volume with the 2 SSDs for my data. ZimaOS installed Plex on the eMMC OS volume.
When I attempt to create a library, I cannot see the data volume. I did see the following instructions that might help, but I’m not really sure what it means.
“map your device’s media location in ‘Host Path’ and link it to Plex’s ‘Container Path’ at /Media for seamless access to add a media library in Plex.
Will this fix my problem? Can you please translate the above instruction to something a newbee would understand?
Thanks in advance,
Ozzie
