This file will play fine on my computer, both via Plex and via VLC, but won’t play on the Xbox. If it can’t play directly, shouldn’t it transcode automatically?
It just sits at a black screen and does nothing on the Xbox.
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 625 MiB
Duration : 26mn 13s
Overall bit rate : 3 333 Kbps
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Main@L3.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 26mn 13s
Bit rate : 3 133 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.113
Stream size : 588 MiB (94%)
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 26mn 13s
Bit rate mode : Constant
Bit rate : 192 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 44.1 KHz
Compression mode : Lossy
Stream size : 36.0 MiB (6%)
