Problems playing hevc main 10
Hello community,
I want to understand why plex player can not play hevc main 10 videos correctly. The colors are messed up.
I am running that same video on MPC and it is working just fine ! My GPU supports HEVC decoding (Radeon 6900XT)
Is there anything I can do to make it work? Or simply it does not support?
Thanks,
JP
Are you sure it’s because of main 10 and not hdr? If you direct play an hdr video on a device that doesn’t support it, you get messed up colors like you describe. To fix this, you’ll need to turn on hdr tone mapping in your server settings.
Thanks for the response.
The thing is: I am running that same file on the same computer with MPC and it is working perfectly. I ran this on Plex Media Player(Server) and also on my Sony TV. Same results.
I have tone mapping enabled already as hable.
Thanks again,
JP
Which specific Plex player app are you using? And what version?
Current options (on PC) are Plex Desktop (Windows/Linux) or Plex HTPC (Windows/Linux). These are available for Macs as well. Or are you referring to the web app via a browser?
I ask because “Plex Media Player” is a now very old and no longer developed app and was replaced by the separate desktop and HTPC app I mentioned above.
HEVC is definitely supported by both of the apps above (desktop and HTPC). Your mileage may vary if you’re using the web app as playback will be determined by the browser’s capabilities.
Also, please post the XML info (the first 40 lines or so) of a file you with which you are experiencing issues.
I am sorry … I use Plex for a very long time :slight_smile:
I am on Plex for Windows Version 1.109.0.329-ea562b95
XML is not showing up here …. it is black.
Follow the mediaInfo export:
General
Unique ID : 32120575400305691591967416410445423413 (0x182A32A2FBEC92F76276400DF137A335)
Complete name : G:\My Download Files_Torrents\Incoming\radarr\Smurfs 2025 2160p iT WEB-DL DDP5 1 Atmos DV H 265-BYNDR\Smurfs 2025 2160p iT WEB-DL DDP5 1 Atmos DV H 265-BYNDR.mkv
Format : Matroska
Format version : Version 4
File size : 9.32 GiB
Duration : 1 h 29 min
Overall bit rate : 14.9 Mb/s
Frame rate : 23.976 FPS
Writing application : mkvmerge 93.0 (‘Goblu’) 64-bit
Writing library : libebml v1.4.5 + libmatroska v1.7.1
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main 10@L5@High
HDR format : Dolby Vision, Version 1.0, Profile 5, dvhe.05.06, BL+RPU, no metadata compression
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 14.1 Mb/s
Width : 3 838 pixels
Height : 1 602 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.096
Stream size : 8.84 GiB (95%)
Default : Yes
Forced : No
Audio
Format : E-AC-3 JOC
Format/Info : Enhanced AC-3 with Joint Object Coding
Commercial name : Dolby Digital Plus with Dolby Atmos
Codec ID : A_EAC3
Bit rate mode : Constant
Bit rate : 768 kb/s
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 492 MiB (5%)
Title : English
Language : English
Service kind : Complete Main
Default : Yes
Forced : No
Complexity index : 16
Number of dynamic objects : 15
Bed channel count : 1 channel
Bed channel configuration : LFE
Dialog Normalization : -25 dB
compr : -0.28 dB
dialnorm_Average : -25 dB
dialnorm_Minimum : -25 dB
dialnorm_Maximum : -25 dB
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Duration : 6 s 423 ms
Bit rate : 74 b/s
Frame rate : 0.467 FPS
Count of elements : 3
Stream size : 60.0 Bytes (0%)
Title : Forced
Language : English (US)
Default : No
Forced : Yes
Text #2
Format : UTF-8
Duration : 1 h 22 min
Bit rate : 72 b/s
Frame rate : 0.298 FPS
Count of elements : 1479
Stream size : 43.9 KiB (0%)
Default : No
Forced : No
Text #3
Format : UTF-8
Bit rate : 77 b/s
Frame rate : 0.337 FPS
Count of elements : 1674
Stream size : 46.8 KiB (0%)
Title : CC
Default : No
Forced : No
Text #4
Format : UTF-8
Duration : 1 h 28 min
Bit rate : 65 b/s
Frame rate : 0.263 FPS
Count of elements : 1402
Stream size : 42.8 KiB (0%)
Title : French
Language : French
Default : No
Forced : No
Text #5
Format : UTF-8
Bit rate : 65 b/s
Stream size : 42.9 KiB (0%)
Title : Canadian
Language : French (CA)
Default : No
Forced : No
Menu
00:00:00.016 : en:Chapter 01
00:10:42.158 : en:Chapter 02
00:20:15.356 : en:Chapter 03
00:30:50.741 : en:Chapter 04
00:41:23.290 : en:Chapter 05
00:51:19.053 : en:Chapter 06
01:01:28.871 : en:Chapter 07
01:11:16.167 : en:Chapter 08
01:20:17.333 : en:Chapter 09
I just tried to modify the quality and I am getting:
File is unplayable. DoVi (Profile 5) color space is not supported.
Thanks again,
JP
Plex cannot transcode Dolby Vision for licensing reasons. And because this is profile 5, there is no HDR10 fallback.
Thanks for the explanation !
Unfortunately, none of my devices support DV.
I will have to skip those then.
Thanks again !
JP
I suggest you try to avoid DV files. I assume you can configure Radarr to specifiy to avoid DV files. I assume, but I don’t use it myself, so I don’t know for sure…
Yeah ! I googled about it and found the way of doing it.
Thanks !
