Problems starting streaming on a VM PMS
Hi @ChuckPa
I hope that you might could help me out.
I have two servers:
1: Running on a NUC 11 Pro with no VM - But pure Ubuntu Server 20.04 LTS - Working flawlessly
2: Got an new NUC 10 Perfomance today with I7.
Server 1 can stream on my TV no problems . Server 2 - Transcoder is dying . NUC spins up the fan.
The VM has GPU Passthough enable :
cd /dev/dri && ls -la
drwxr-xr-x 2 root root 100 Jun 9 18:05 by-path
crw-rw---- 1 root video 226, 0 Jun 9 18:05 card0
crw-rw---- 1 root video 226, 1 Jun 9 18:05 card1
crw-rw---- 1 root video 226, 128 Jun 9 18:05 renderD128
sudo lspci -nnv | grep VGA
00:02.0 VGA compatible controller [0300]: Device [1234:1111] (rev 02) (prog-if 00 [ VGA controller])
00:10.0 VGA compatible controller [0300]: Intel Corporation Device [8086:9bca] (rev 04) (prog-if 00 [ VGA controller])
When I stream from a browser and or my iPhone with low quality , I can see (hw) transcoding is working. Im running the latest ICG on the server. But its not all the media that I have problems with, its only some of them, but most of them won’t start on the tv. Everything can start up on the browser or Iphone.
My TV is an LG G1 EVO .
Morphy
SOLVED
Somehow on the TV - the tv has been reset on the new player that has been installed .
DTS wasnt enabled so it would not play media with DTS content , but should the system not transcode then?.?.
