Problems with Absolute Order
Hello? Is there someone at Plex?
Plex have already commented they’re looking into alternate orders when they introduced the new Plex TV Series agent (don’t read that as a commitment that it’ll happen or that it’ll happen soon).
They usually don’t comment on specific feature suggestions unless they’re unclear… they also usually don’t comment on their roadmap (unless things are 100% set in stone).
Yes but now it isn’t working, I set absolute order but every time metadata refreshes they will follow aired order
I’ve moved this into a separate thread as “having problems with absolute order” doesn’t really belong into the feature suggestion to support alternate orders from TheTVDb or TMDb. I hope you can respect that.
How about starting from square one and how absolute order isn’t working for you?
Also… what agent you’re currently using for the library in question and how are your files named/organized?
NO, my problem is that there isn’t netflix/alternate order, and for “fixing it” I set absolute order (I have no names or metadata, but at least is not messed up like aired order)
