Plex Media Server: 1.32.5.7349 (Docker via Ubuntu 22.04)
Hardware Transcoding: Intel GPU & Software tested
Currently, on a variety of clients where the media actually works in Direct Play, I’m having the problems that as soon as subtitles are enabled, the video either quits right at the beginning or just in the middle (not always) with an error. When I play the video without subtitles it works, as well as when it is transcoded.
The problem occurs not only with this file, also with others, this is just an example.
The following log output is generated for this purpose:
Aug 10, 2023 13:30:03.521 [140098200496952] Fehler — [Req#559644] Unable to find client profile for device; platform=webOS, platformVersion=5.4.3, device=webOS 5.4.3, model=OLED65CX3LA
Aug 10, 2023 13:30:07.867 [140098274954040] Info — [Req#5596ce] [Plex for LG] [XXX:XXX] videoStream: {
"id": 1666128,
"streamType": 1,
"default": true,
"codec": "hevc",
"index": 0,
"bitrate": 7519,
"bitDepth": 10,
"chromaLocation": "left",
"chromaSubsampling": "4:2:0",
"codedHeight": 808,
"codedWidth": 1920,
"colorPrimaries": "bt709",
"colorRange": "tv",
"colorSpace": "bt709",
"colorTrc": "bt709",
"frameRate": 23.976,
"height": 802,
"level": 123,
"profile": "main 10",
"refFrames": 1,
"width": 1918,
"displayTitle": "1080p (HEVC Main 10)",
"extendedDisplayTitle": "1080p (HEVC Main 10)"
Aug 10, 2023 13:30:07.867 [140098274954040] Info — [Req#5596ce] [Plex for LG] [XXX:XXX] audioStream: {
"id": 1666129,
"streamType": 2,
"selected": true,
"default": true,
"codec": "eac3",
"index": 1,
"channels": 6,
"bitrate": 256,
"language": "Deutsch",
"languageTag": "de",
"languageCode": "deu",
"audioChannelLayout": "5.1(side)",
"samplingRate": 48000,
"title": "German",
"displayTitle": "Deutsch (EAC3 5.1)",
"extendedDisplayTitle": "German (Deutsch EAC3 5.1)"
Aug 10, 2023 13:30:07.867 [140098274954040] Info — [Req#5596ce] [Plex for LG] [XXX:XXX] subtitleStream: {
"id": 1666131,
"streamType": 3,
"selected": true,
"codec": "srt",
"index": 3,
"bitrate": 0,
"title": "German (Forced)",
"displayTitle": "Deutsch (SRT)",
"extendedDisplayTitle": "German (Forced) (Deutsch SRT)"
Aug 10, 2023 13:30:14.926 [140098211531576] Error — [Req#5597f8] [Plex for LG] [XXX:XXX] [Subtitles: Connection Monitor] An unknown error ocurred: <html><head><title>Bad Request</title></head><body><h1>400 Bad Request</h1></body></html>
The “Bad Request” occurs three times, then the stream stops.
If I set “Burn in subtitles” to “Always”, it works of course, as it then transcodes.
Does anyone have an idea how to solve this problem or is this a general problem with the client or the current server software?
