Problems with Mojave last version 10.14.4
Server Version#:
Player Version#:1
Giuseppe Caputo
Apr 12, 10:49 AM PDT
Plex Email: velan-x@libero.it
Plex Username: gxx
Message:
Hello, I have problems with Plex since I installed the latest Mac Mojave 10.14.4 software version while with the previous version it was fine. It does not transfer all recently added files, TV series movies and so on to the server. The server starts working regularly but then it doesn’t show them, it doesn’t erase them and it’s impossible to interact. Only those previously loaded can be seen, all new ones are not possible. I have the latest version of Plex 1.15.3.876, I have also installed the software of both Mac and Plex again but it does not work and it is impossible to return the Mac to the Mojave version 10.14.3. This word appears on the start page: 'An unexpected error occurred loading the dashboard
If you continue to encounter errors, please visit our forums. ’ Please be able to help me thanks.
Thank You in advance
I’m running Mojave 10.14.4 with version 1.15.4.919 with no known issues. I would suggest the best way forward would be to properly uninstal PMS and start again. Follow the instructions exactly, not just Trash the application.
https://support.plex.tv/articles/201941078-uninstall-plex-media-server/
Thank you so much. for fvore where I can find the version 1.15.4.919 for Mac (I can have the link) because I can’t find it, there is still only the previous one. Thanks again
Thank you so much. Please where can I find the 1.15.4.919 version for Mac (I can have the link) because I can’t find it, only the previous one is still there. Thanks again
Thank you so much. Please where can I find the 1.15.4.919 version for Mac (I can have the link) because I can’t find it, only the previous one is still there. I don’t have a plex pass. Thanks again
I am afraid 1.15.3.876 is the latest available if you do not have a Plex Pass.
You will need to wait until 1.15.4.919 is released to the public channel to get that version
Ok, I’ll wait then, thank you so much
The previous version will work as well, you just need to uninstal correctly
Thanks a lot but I would like to avoid when uninstalling because I have a lot of libraries created on my account and I would lose them all, it would take a long time to create them all again. Thanks anyway
You don’t lose Libraries just the Metadata
But do I have to recreate the libraries or find them as they are? Sorry but I’m incompetent in these things
Your files stay put, just the metadata goes
Ok in the next few days I’ll do this thing then. Thank you so much for your availability. Ciao
With my FIRST installation of PLEX version 1.15.3.816 (last version downloadable for Mac), I have the same problem…
Done, problem solved thank you!
