Good morning, I’m having problems with Plex, I bought the Android TVBOX H96 MAX M9 and install Plex, I’m going to watch a series and it gets stuck, I must lower the video quality to go smoothly, I do not detect the optimum quality automatically.
What do I do to fix it?
Here are the specifications of the H96 MAX M9:
-Operating system: Android 14.0
-CPU : Rockchip RK3576 Octa Core ( Quad Cortex A72 + Quad Cortex A53)
-GPU : ARM Mali G52 MC3 GPU
-RAM : 8GB
-ROM : 128GB
-WiFi 2.4G/5G WiFi6, BT5.4
-Support 8K, AV1 video decoding
USB host 1 USB 3.0 Hi-Speed, 1 USB 2.0
-Comes with a 2.4Ghz voice remote control
There are three options for H96 MAX M9:
DDR4 8GB + 128GB + Wifi6 + BT5.4 + 1000M
And I have a synology 918+ server with 1000 mbps ethernet connection.
