Problems with watch together from personal library
Hello Everyone,
I’m new to plex and wanted to try out the watch together feature.
I’ve set up a media server for tv shows, but the watch together option is not available when clicking on the episode and the 3 dots.
I did the same, but this time setup a movie library, not TV show and after some renaming of the episodes, it found them and the watch together button was there.
I’m not sure if I did something wrong with the TV shows media server setup, but if anyone has similar problem, I used this workaround by making the TV Show episodes recognized as movies.
I really like the software you’ve created, keep up the great work.
Watch together works for me. Make sure that you are in the actual episode itself, where you have details about the show. If you are on the season view (you see a list of episodes), or the show view (you see a list of seasons) then it won’t work.
All of a sudden today, it worked for me too. Without changing anything, kind of weird.
Thanks for the reply tho
