Upgrading from Hauppauge WinTV-dualHD to WinTV-quadHD
Server Version#: plexmediaserver-1.23.4.4805-186bae04e.x86_64
Player Version#: Windows10 Version: 1.33.0.2444-a220eae4
Tuner Make/Model: Hauppauge WinTV-dualHD WinTV-quadHD
Guide/Lineup name: n/a
Using XMLTV?: n/a
Channel number/Name: n/a
Hi, I’m having problems upgrading my TV tuner. Under settings, Live TV & DVR I deleted my old tuner (Hauppauge WinTV-dual HD). I then swapped the old device out and replaced it with the new device (Hauppauge WinTV-quadHD). I went back in to settings, Live TV & DVR and clicked on SET UP PLEX DVR. It shows 2 devices both identify as Hauppage WinTV-quadHD. Note: From what I found on the PLEX site is says it show up as 2 Hauppauge WinTV-dualHD devices. I also get an exclamation sign after each device which indicates “This tuner isn’t officially supported by PLEX, click for more information”. If I click for more information it talks about compatible tuners and does list the Hauppauge WinTV-quadHD as an officially supported device. I then select either device, click on continue, which in the upper left corner says Unsupported Tuner, leaving the only option to click on ENABLE UNSUPPORTED TUNER which I do. This takes me to the DVR Setup screen to SCAN CHANNELS. After scanning the channels it does not find any. If I try to go back to my old device it no longer finds channels. Both device actually work fine when tested when plugged into a PC running the Hauppauge WinTV version 10 application. I also tested the antenna plugged into a tv to make sure it was okay. So I know both my tuners and antenna work fine but not when connected to my plexmediaserver. How do I remove any old WinTV information from PLEX so I can get a clean start? I do not want to remove anything other than tuner or dvr related information.
There are 2 section of the plex tuner service log here. The first section looks like it is recognizing my new quad tuners, but the second section is showing some failures to make a compound device. Not sure where to look for information on the actual channels it is scanning.
Jul 18, 2021 19:40:50.499 [0x7f5346971b38] INFO - [I] web_service_t::process_device_discovery
Jul 18, 2021 19:40:50.500 [0x7f5346971b38] INFO - [I] device_reactor_t::get_device_list ()
Jul 18, 2021 19:40:52.505 [0x7f5346971b38] INFO - [I] SAT2IP - discover_satip_servers(): no servers found
Jul 18, 2021 19:40:52.925 [0x7f5346971b38] INFO - [I] v4l::DeviceGetList_impl. getting v4l device list
Jul 18, 2021 19:40:52.925 [0x7f5346971b38] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter0/frontend0
Jul 18, 2021 19:40:52.926 [0x7f5346971b38] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter1/frontend0
Jul 18, 2021 19:40:52.927 [0x7f5346971b38] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter2/frontend0
Jul 18, 2021 19:40:52.927 [0x7f5346971b38] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter3/frontend0
Jul 18, 2021 19:40:52.931 [0x7f5346971b38] INFO - [I] dvb_device_factory_t::get_device_list. Id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5.1/1-5.1:1.0:0, Name quadHD-A, Standards 8
Jul 18, 2021 19:40:52.931 [0x7f5346971b38] INFO - [I] dvb_device_factory_t::get_device_list. Id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5.1/1-5.1:1.0:1, Name quadHD-A, Standards 8
Jul 18, 2021 19:40:52.931 [0x7f5346971b38] INFO - [I] dvb_device_factory_t::get_device_list. Id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5.3/1-5.3:1.0:0, Name quadHD-A, Standards 8
Jul 18, 2021 19:40:52.931 [0x7f5346971b38] INFO - [I] dvb_device_factory_t::get_device_list. Id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5.3/1-5.3:1.0:1, Name quadHD-A, Standards 8
Jul 18, 2021 19:40:52.931 [0x7f5346971b38] INFO - [I] onetv_factory::DeviceGetListEx >>
Jul 18, 2021 19:40:52.931 [0x7f5346971b38] INFO - [I] onetv_factory::DeviceGetListEx. Found device 7531:3
Jul 18, 2021 19:40:52.931 [0x7f5346971b38] INFO - [I] onetv_factory::DeviceGetListEx. Found device 257:257
Jul 18, 2021 19:40:52.931 [0x7f5346971b38] INFO - [I] onetv_factory::DeviceGetListEx. Found device 8256:33901
Jul 18, 2021 19:40:52.931 [0x7f5346971b38] INFO - [I] onetv_factory::DeviceGetListEx. Found device 1367:32801
Jul 18, 2021 19:40:52.931 [0x7f5346971b38] INFO - [I] onetv_factory::DeviceGetListEx. Found device 1033:90
Jul 18, 2021 19:40:52.931 [0x7f5346971b38] INFO - [I] onetv_factory::DeviceGetListEx. Found device 1250:1028
Jul 18, 2021 19:40:52.931 [0x7f5346971b38] INFO - [I] onetv_factory::DeviceGetListEx. Found device 7531:2
Jul 18, 2021 19:40:52.931 [0x7f5346971b38] INFO - [I] device_manager_t::get_device_list. Device quadHD-A, id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5.1/1-5.1:1.0:0, tuners 1, state 0, standards 8
Jul 18, 2021 19:40:52.931 [0x7f5346971b38] INFO - [I] device_manager_t::get_device_list. Device quadHD-A, id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5.1/1-5.1:1.0:1, tuners 1, state 0, standards 8
Jul 18, 2021 19:40:52.931 [0x7f5346971b38] INFO - [I] device_manager_t::get_device_list. Device quadHD-A, id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5.3/1-5.3:1.0:0, tuners 1, state 0, standards 8
Jul 18, 2021 19:40:52.931 [0x7f5346971b38] INFO - [I] device_manager_t::get_device_list. Device quadHD-A, id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5.3/1-5.3:1.0:1, tuners 1, state 0, standards 8
Jul 18, 2021 19:40:52.931 [0x7f5346971b38] INFO - [I] web_service_t::process_compound_devices. Merged 2 tuners for device dvb#v4l#/sys/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5.1/1-5.1:1.0:0014128759
Jul 18, 2021 19:40:52.931 [0x7f5346971b38] INFO - [I] web_service_t::process_compound_devices. Merged 2 tuners for device dvb#v4l#/sys/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5.3/1-5.3:1.0:0014128759
Jul 18, 2021 19:40:52.933 [0x7f5346563b38] INFO - [I] web_service_t::process_device_status
Jul 18, 2021 19:40:52.933 [0x7f5346563b38] INFO - [I] device_reactor_t::get_device_list (dvb#v4l#/sys/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5.1/1-5.1:1.0:0014128759)
Jul 18, 2021 19:40:52.933 [0x7f5346563b38] INFO - [I] v4l::DeviceGetList_impl. getting v4l device list
Jul 18, 2021 19:40:52.933 [0x7f5346563b38] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter0/frontend0
Jul 18, 2021 19:40:52.933 [0x7f5346563b38] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter1/frontend0
Jul 18, 2021 19:40:52.933 [0x7f5346563b38] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter2/frontend0
Jul 18, 2021 19:40:52.933 [0x7f5346563b38] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter3/frontend0
Jul 18, 2021 19:40:52.934 [0x7f5346563b38] INFO - [I] dvb_device_factory_t::get_device_list. Id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5.1/1-5.1:1.0:0, Name quadHD-A, Standards 8
Jul 18, 2021 19:40:52.934 [0x7f5346563b38] INFO - [I] dvb_device_factory_t::get_device_list. Id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5.1/1-5.1:1.0:1, Name quadHD-A, Standards 8
Jul 18, 2021 19:40:52.934 [0x7f5346563b38] INFO - [I] device_manager_t::get_device_list. Device quadHD-A, id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5.1/1-5.1:1.0:0, tuners 1, state 0, standards 8
Jul 18, 2021 19:40:52.934 [0x7f5346563b38] INFO - [I] device_manager_t::get_device_list. Device quadHD-A, id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5.1/1-5.1:1.0:1, tuners 1, state 0, standards 8
Jul 18, 2021 19:40:52.936 [0x7f5346666b38] INFO - [I] web_service_t::process_get_scanners
Jul 18, 2021 19:40:52.967 [0x7f5346563b38] INFO - [I] web_service_t::process_device_status
Jul 18, 2021 19:40:52.967 [0x7f5346563b38] INFO - [I] device_reactor_t::get_device_list (dvb#v4l#/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4.3/1-4.3:1.0:0014128759)
Jul 18, 2021 19:40:52.967 [0x7f5346563b38] INFO - [I] v4l::DeviceGetList_impl. getting v4l device list
Jul 18, 2021 19:40:52.967 [0x7f5346563b38] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter0/frontend0
Jul 18, 2021 19:40:52.967 [0x7f5346563b38] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter1/frontend0
Jul 18, 2021 19:40:52.967 [0x7f5346563b38] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter2/frontend0
Jul 18, 2021 19:40:52.967 [0x7f5346563b38] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter3/frontend0
Jul 18, 2021 19:40:52.969 [0x7f5346563b38] WARN - [E] web_service_t::get_device_status. Failed to make compound device for device uuid dvb#v4l#/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4.3/1-4.3:1.0:0014128759
Jul 18, 2021 19:40:52.972 [0x7f534686eb38] INFO - [I] web_service_t::process_device_status
Jul 18, 2021 19:40:52.972 [0x7f534686eb38] INFO - [I] device_reactor_t::get_device_list (dvb#v4l#/sys/devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.0:0014073429)
Jul 18, 2021 19:40:52.972 [0x7f534686eb38] INFO - [I] v4l::DeviceGetList_impl. getting v4l device list
Jul 18, 2021 19:40:52.972 [0x7f534686eb38] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter0/frontend0
Jul 18, 2021 19:40:52.973 [0x7f534686eb38] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter1/frontend0
Jul 18, 2021 19:40:52.973 [0x7f534686eb38] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter2/frontend0
Jul 18, 2021 19:40:52.973 [0x7f534686eb38] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter3/frontend0
Jul 18, 2021 19:40:52.975 [0x7f534686eb38] WARN - [E] web_service_t::get_device_status. Failed to make compound device for device uuid dvb#v4l#/sys/devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.0:0014073429
Jul 18, 2021 19:40:55.361 [0x7f5346666b38] INFO - [I] web_service_t::process_device_discovery
Jul 18, 2021 19:40:55.361 [0x7f5346666b38] INFO - [I] device_reactor_t::get_device_list ()
Jul 18, 2021 19:40:57.367 [0x7f5346666b38] INFO - [I] SAT2IP - discover_satip_servers(): no servers found
Jul 18, 2021 19:40:57.786 [0x7f5346666b38] INFO - [I] v4l::DeviceGetList_impl. getting v4l device list
Jul 18, 2021 19:40:57.787 [0x7f5346666b38] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter0/frontend0
Jul 18, 2021 19:40:57.788 [0x7f5346666b38] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter1/frontend0
Jul 18, 2021 19:40:57.788 [0x7f5346666b38] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter2/frontend0
Jul 18, 2021 19:40:57.789 [0x7f5346666b38] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter3/frontend0
Jul 18, 2021 19:40:57.793 [0x7f5346666b38] INFO - [I] dvb_device_factory_t::get_device_list. Id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5.1/1-5.1:1.0:0, Name quadHD-A, Standards 8
Jul 18, 2021 19:40:57.793 [0x7f5346666b38] INFO - [I] dvb_device_factory_t::get_device_list. Id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5.1/1-5.1:1.0:1, Name quadHD-A, Standards 8
Jul 18, 2021 19:40:57.793 [0x7f5346666b38] INFO - [I] dvb_device_factory_t::get_device_list. Id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5.3/1-5.3:1.0:0, Name quadHD-A, Standards 8
Jul 18, 2021 19:40:57.793 [0x7f5346666b38] INFO - [I] dvb_device_factory_t::get_device_list. Id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5.3/1-5.3:1.0:1, Name quadHD-A, Standards 8
Jul 18, 2021 19:40:57.793 [0x7f5346666b38] INFO - [I] onetv_factory::DeviceGetListEx >>
