Progress Bar wont go away...
Running Rasplex on a Pi/2, and while watching some movies with the family today the progress bar remains on the screen, and wont go away…
Stopped the movie, went back to the main menu, then back to the movie, started playing fine, so used FF to get back to where we were, and when we got back there, the progress bar remain again…nothing I tried would make it go away…
Is there some setting I overlooked that would cause it to remain all the time when playing video?
Not normal, suggest that you reflash your SD card with a fresh install, possible card corruption.
Regards
