Stop Play Fastforward Bar won't go away
When pausing a movie or tvshow the play stop fastforward bar shows up, when pressing resume on remote control or pressing play using the iPhone plex app as remote the bar won’t go away.
How to troubleshoot?
I have the same issue. Are you running on A RPi Zero? That’s what I’m running.
Ditto
@aaronson2012 - I saw you posted it as an issue on github and my specs
Problem is solved by reinstalling rasplex on raspberry pi and configured it again.
