RasPlex Onscreen Display won't go away.
Hey guys,
Having an issue with the last couple of releases. I used a Rasberry Pi2 with latest release (although the last release had the same issue – no issue before that). If I use any playback feature - skip back or forward, or pause, etc. – the OSD comes up (which is fine), but it will not go away on its own. I have to stop and resume the movie to get it to stop.
I am using a Logitech Ultimate remote setup - using a FLIRC to allow for IR remote access. It’s worked perfectly since v.0.6. But last two versions have had this issue. Could it be the auto update has left me with a not so clean install?
Any thoughts?
CT
This is not normal behaviour, suggest a complete reinstall.
Regards
Update - clean install seems to have fixed the issue.
When you say On Screen Display, do you mean the FF/RW progress bar? Mine started doing this tonight…cant find out what’s causing it…
