PS4 Audio??
Hi all/plex team,
I have recently added some media to my plex library which has 5.1 audio and works fine on my PC when it is plugged directly into my sound bar.
They also sound absolutely fine on the PS3 version which I cannot understand at all.
However when I play the same titles through my PS4 they aren’t as good quality, they sound a bit tinny and you can quite clearly tell that there is a difference in quality
I have also noticed that there is a slight AV desync which is annoying.
Anyone else having this problem??
Will there be some sort of fix for this soon plex team??
I’m noticing an issue where the audio to video sync isn’t correct. After restarting plex and restarting the file from the beginning it works fine. This happens rarely but it started happening since the last update.
Just heads up to the plex team.
