Server Version#: 1.20.0.3181
Player Version#: PS4 Early Access
So when watching tv with embedded subtitles, on the regular version it remembers if subtitles are turned on between episodes and you can enable/disable them on the fly.
In the new early access version you have to re-enable subtitles on every episode, at which point it will restart the ep from the beginning with them turned on.
Haven’t tested it with a movie with external subs yet but I expect the behaviour is similar.
Also there seems to be a memory leak because the app tends to lock up after 10 or so episodes, especially when fast forwarding the first few min. Skip intro button is about 50/50 on if it will play properly or just give audio.
