PS5 multiple issues with subtitles
Server Version#: 1.26.1.5772
Player Version#: 5.36.1
When I enable subtitles on the PS5 client, I always get an error which says “Something went wrong, please try again later”, when backing out of the menu. Subtitles usually work, in spite of the message.
However, subtitles often stop working after playing some of a video, then pausing, then resuming. Once subtitles stop working, they cannot be re-enabled.
I have tried various combinations of settings within the app, nothing seemed to change the behavior.
Very annyoing bug
Are you seeing the same issue?
