"pull request": symlinking and restart in PlexConnect_daemon.bash
I'm not set up to use GitHub but was wondering if you're interested in these two changes to PlexConnect_daemon.bash
- resolve INSTALL_DIR automatically, incl under symlinking [from http://stackoverflow.com/a/246128]
- restart option
The first allows for symlinking from whatever startup location your particular system prefers.
#!/bin/bash
sample start stop script
Package
DNAME=“PlexConnect”
PNAME=“PlexConnect_daemon”
Others, w/path resolution from http://stackoverflow.com/a/246128
SOURCE="${BASH_SOURCE[0]}"
while [ -h "SOURCE" ]; do DIR="( cd -P “$( dirname “SOURCE" )" && pwd )" SOURCE="(readlink “$SOURCE”)”
[[ $SOURCE != /* ]] && SOURCE=”$DIR/SOURCE" done INSTALL_DIR="( cd -P "$( dirname “SOURCE" )" && pwd )" PYTHON="python" PROGRAM="{INSTALL_DIR}/{PNAME}.py" PID_FILE="/var/{PNAME}.pid”
start_daemon ()
{PYTHON} {PROGRAM} --pidfile ${PID_FILE}
stop_daemon ()
kill cat ${PID_FILE}
wait_for_status 1 20 || kill -9 cat ${PID_FILE}
rm -f ${PID_FILE}
daemon_status ()
if [ -f {PID_FILE} ] && kill -0 `cat {PID_FILE}` > /dev/null 2>&1; then
return
fi
rm -f ${PID_FILE}
return 1
wait_for_status ()
counter=2 while [ {counter} -gt 0 ]; do
daemon_status
[ $? -eq $1 ] && return
let counter=counter-1
sleep 1
done
return 1
Determine if the network is up by looking for any non-loopback network interfaces.
Currently supports only OSX “Darwin” OS
CheckForNetwork()
local test
if [ -z "${NETWORKUP:=}" ]; then
	test=$(ifconfig -a inet 2>/dev/null | sed -n -e '/127.0.0.1/d' -e '/0.0.0.0/d' -e '/inet/p' | wc -l)
	if [ "${test}" -gt 0 ]; then
		NETWORKUP="-YES-"
	else
		NETWORKUP="-NO-"
	fi
fi
Determine if the operating system is OSX “darwin”. If so, then delay running the rest of
the script until the network is up. This avoids the binding of PlexConnect to the
loopback address which occurs if the bash script is called from a LaunchDaemon/plist
file at boot time.
if [[ “OSTYPE" == "darwin"* ]]; then CheckForNetwork while [ "{NETWORKUP}” != “-YES-” ]
do
sleep 5
NETWORKUP=
CheckForNetwork
done
fi
Now do what you need to do.
case 1 in start) if daemon_status; then echo {DNAME} is already running
else
echo Starting {DNAME}... start_daemon fi ;; stop) if daemon_status; then echo Stopping {DNAME}…
stop_daemon
else
echo {DNAME} is not running fi ;; status) if daemon_status; then echo {DNAME} is running
exit 0
else
echo ${DNAME} is not running
exit 1
fi
restart)
# Restart the daemon.
$0 stop && sleep 2 && $0 start && sleep 2 && $0 status
exit 1
esac
