I have just set up the new HTPC Plex app on a Windows 10 PC attached to my main TV. I want to find the simple way for the family to control HTPC Plex and my Sony android TV with all the streaming services apps on it using a single remote.
I came across the PulseEight USB CEC adapter, I see lots of mentions of this working with Kodi, but does it work fully to control Plex?
If not what other alternatives should I consider, maybe a universal remote. I see Logitech are stopping making the Harmony remotes, so what are the best alternatives?
As long as all your buttons appear in some way in the log file of Plex HTPC, you can even extend the number of supported buttons: Create your own inputmap | Plex Support
