Server Version#: 1.15.3.876 (current version as of this post)
Player Version#: see below
I recently installed PLEX 64-bit on my Synology DS-1019+ (with Plex Pass and hardware transcoding turned on) and have been having a lot of issues with it, but they’re not very consistent. Right now the issue is playback on devices. I used Plex for years and years on Windows and found it to be quite stable, but I am really struggling to get stable usage of it on my Synology (which is depressing because it was the main reason I bought the 1019+).
Fire TV 4K (v.7.10.0.8875): won’t play the original (hardware limitation), but when set to transcode at 20mbps (I also tried 12mbps) it pauses playback every 10 seconds or so, freezes for 2-3 seconds, then resumes. Stopped Plex, restarted it, turned on debug logging, tried again. Got an error about the server not being powerful enough for playback. Repeat pausing issue again.
4K Apple TV (v.1.40.1.11962): plays original quality MKV without issue, when manually set to 20mbps it won’t play the movie at all. Exited the Apple TV app, killed it, restarted it, tried playback again at 20mbps. Black screen for a bit, then got a new error I’ve never seen before: “Couldn’t create the playback session for this item. Could not direct play because: App cannot direct play this item. Direct play is disabled. Could not transcode because: not enough bandwidth for any playback of this item. Cannot convert to below minimum bandwidth of 103kbps”.
I also tried the macOS desktop client and it worked without issue (though I suspect it was playing back the original quality file), though upon second attempt it says Plex is unreachable.
Throughout all this I was watching the CPU usage on the Synology NAS and it never went above 30%, so this doesn’t appear to be a CPU-dependant playback issue.
Here are the logs: Plex Media Server Logs_2019-04-05_19-24-17.zip (2.5 MB)
I think I filled in all the blanks on what is needed to report issues - please let me know if I missed anything.
EDIT: A few hours ago I installed two 512 GB M.2 SSDs into the 1019+ and created a read/write SSD cache…would that have anything to do with this? Would this impact the way Plex transcodes video? I wouldn’t think so, but I figured I’d mention it…
EDIT 2: I’ve done more testing and have another data point. Playback of h.264 MKVs work fine. Playback of older MKVs using VC-1 on the same hardware (Fire TV and Roku) has the pausing/buffering problem. On the Fire TV is pauses (freezes) for a few seconds, on the Roku it goes to a black buffering screen. So I’m wondering if this is really a transcoding of VC-1 MKVs problem…?
EDIT 3: Done more testing, digging up MKVs with VC-1 format videos and, yep, buffering every 20 seconds or so. MKVs with h.264 content, zero issues. So this really seems like a VC-1 related issue.
Never saw anyone talking about it as a known issue. Dang.
