Python SDK for Tivo Now
An alternative to TiVo's Java-based HME (Home Media Extensions) SDK, this package helps you to develop HME applications in Python. LGPL 2.1+, except where noted. (Most of the example apps are ported from TiVo's SDK, and as such are under the Common Public License.) More of a framework than a library. Python 2.x only, where x >= 3 (or x >= 5 in the next release).
HME for Python includes some features not available in publicly released versions of the Java SDK, such as (with Series 3 or later TiVos) an easy method of changing resolutions between SD and HD, and support for direct text input.
Application can be found here http://wmcbrine.com/tivo/
Tivo forum discussions here. http://www.tivocommunity.com/tivo-vb/showthread.php?t=382883
Please could someone build this app?
