@ChuckPA said:
Let’s back up a second and let me ask about on full-bitrate blu ray mkv rips. What is the encoding and bitrate of these videos?
The example you gave me is not what I’ve seen as a full-bitrate rip. It’s bitrate="29008" and H.264. When I refer to full bluray rips, the bit rates are typically well above 30 Mbps. Regardless, we’ve verified the processor isn’t struggling in any way.
These are blu rays that I ripped with MakeMKV. Since MakeMKV doesn’t transcode the video and just direct rips it from the blu ray and puts it in an MKV, I would assume they are all H.264 and varying bitrates. It looks like most of the movies are in the 20-30 Mbps range.
I just checked one of the files and it is H.264 and audio track I am playing is DTS-HD MA.
Video: MPEG4 Video (H264) 1920x1080 23.976fps [V: English [eng] (h264 high L4.1, yuv420p, 1920x1080)]
Audio: DTS 48000Hz 6ch 6912kbps [A: Surround 5.1 [eng] (dts-hd ma, 48000 Hz, 5.1, s24) [default]]
Audio: Dolby AC3 48000Hz stereo 224kbps [A: Stereo [eng] (ac3, 48000 Hz, stereo, 224 kb/s)]
I pulled up a 5.1 + AC-3 video, selected AC-3 and PMS transcoded to AAC as expected with Chrome without issue.
Playing the same AC-3 selection to the ATV was ‘Direct Stream’ + ‘Direct Stream’ which is expected for any MKV file.
I don’t think I’d expect an issue in that example. You’d need to select the DTS-HD audio and make it transcode to AC3 to get a similar result as with my ATV.
I’m going to ask the very stupid question: "Are you 100% certain your MTU values are all at their default value of 1500 and Jumbo Packets are not enabled? If so, it could easily manifest this way.
I haven’t modified any MTUs on the router, or any client devices. It looks like they’re all 1500.
