I am trying to play LOTR 4k from my plex server in a QNAP TS-251+ NAS.
The CPU on the NAS is going 80% and of course there is high buffering.
I tried playing the movie from both from my LG Plex app but also from my XBOX series X. Same problem.
I understand that the NAS is not powerful enough to transcode this file. My network connection is fast, though.
I am uploading the plex media server log and i would highly appreciate if somebody could help analyze and nail down the problem.
The J1900 CPU in that QNAP does not support HEVC in hardware
nor does it have enough CPU power to decode in software.
Dec 23, 2020 22:57:33.347 [0x7f8c1e2a1700] ERROR - [Transcode] [FFMPEG] - libva: /share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/lib/dri/iHD_drv_video.so init failed
Dec 23, 2020 22:57:33.418 [0x7f8c1e2a1700] WARN - [Transcode] [FFMPEG] - No quality level set; using default (20).
Dec 23, 2020 22:57:33.432 [0x7f8c1e2a1700] ERROR - [Transcode] [FFMPEG] - libva: /share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/lib/dri/iHD_drv_video.so init failed
Dec 23, 2020 22:57:33.434 [0x7f8c1e2a1700] ERROR - [Transcode] [FFMPEG] - No support for codec hevc profile 2.
Dec 23, 2020 22:57:33.434 [0x7f8c1e2a1700] ERROR - [Transcode] [FFMPEG] - Failed setup for format vaapi_vld: hwaccel initialisation returned error.
Dec 23, 2020 22:57:33.435 [0x7f8c1e2a1700] WARN - [Transcode] Codecs: avcodec_open2 returned -95 for decoder ‘hevc’
Dec 23, 2020 22:57:33.435 [0x7f8c1e2a1700] ERROR - [Transcode] [FFMPEG] - Cannot load libcuda.so.1
Dec 23, 2020 22:57:33.435 [0x7f8c1e2a1700] ERROR - [Transcode] [FFMPEG] - Could not dynamically load CUDA
Dec 23, 2020 22:57:33.437 [0x7f8c1e2a1700] ERROR - [Transcode] [FFMPEG] - libva: /share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/lib/dri/iHD_drv_video.so init failed
Dec 23, 2020 22:57:33.439 [0x7f8c1e2a1700] ERROR - [Transcode] [FFMPEG] - No support for codec hevc profile 2.
Dec 23, 2020 22:57:33.439 [0x7f8c1e2a1700] ERROR - [Transcode] [FFMPEG] - Failed setup for format vaapi_vld: hwaccel initialisation returned error.
Dec 23, 2020 22:57:33.440 [0x7f8c1e2a1700] WARN - [Transcode] Codecs: avcodec_open2 returned -95 for decoder ‘hevc’
Dec 23, 2020 22:57:33.440 [0x7f8c1e2a1700] ERROR - [Transcode] [FFMPEG] - Cannot load libcuda.so.1
Dec 23, 2020 22:57:33.440 [0x7f8c1e2a1700] ERROR - [Transcode] [FFMPEG] - Could not dynamically load CUDA
Dec 23, 2020 22:57:33.708 [0x7f8b93a23700] ERROR - Unable to find client profile for device; platform=webOS, platformVersion=4.9.0, device=webOS 4.9.0, model=OLED65C9PLA
Dec 23, 2020 22:57:34.190 [0x7f8b93a23700] ERROR - [Transcode] [FFMPEG] - libva: /share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/lib/dri/iHD_drv_video.so init failed
Dec 23, 2020 22:57:34.276 [0x7f8c1e2a1700] ERROR - [Transcoder] [AVHWDeviceContext @ 0x2665bc0] libva: /share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/lib/dri/iHD_drv_video.so init failed
You also have subtitles involved
Dec 23, 2020 23:54:08.422 [0x7f8b8ba87700] DEBUG - [Transcode] It took 10.000000 ms to retrieve 218 items.
Dec 23, 2020 23:54:08.425 [0x7f8b8ba87700] DEBUG - [Transcode] We’re going to try to auto-select a subtitle.
Dec 23, 2020 23:54:08.425 [0x7f8b8ba87700] DEBUG - [Transcode] Subtitles: Found a candidate subtitle language [eng] for a foreign film
Dec 23, 2020 23:54:08.425 [0x7f8b8ba87700] DEBUG - [Transcode] Audio Stream: 104871, Subtitle Stream: 104874
Dec 23, 2020 23:54:08.438 [0x7f8b8ba87700] DEBUG - [Transcode] Codecs: testing hevc (decoder) with hwdevice vaapi
Dec 23, 2020 23:54:08.438 [0x7f8b8ba87700] DEBUG - [Transcode] Codecs: hardware transcoding: testing API vaapi
Either the format (PGS/VOBSUB/DVDRIP) or the player settings are requiring the subtitles to be burned in ( Not enough CPU power for subtitles , independent of H.265)
Dec 23, 2020 23:54:08.442 [0x7f8b8ba87700] DEBUG - [Transcode] MDE: analyzing media item 124341
Dec 23, 2020 23:54:08.442 [0x7f8b8ba87700] DEBUG - [Transcode] MDE: The Lord of the Rings: The Fellowship of the Ring (2001): Direct Play is disabled
Dec 23, 2020 23:54:08.442 [0x7f8b8ba87700] DEBUG - [Transcode] MDE: The Lord of the Rings: The Fellowship of the Ring (2001): media must be transcoded in order to use the dash protocol
Dec 23, 2020 23:54:08.443 [0x7f8b8ba87700] DEBUG - [Transcode] MDE: The Lord of the Rings: The Fellowship of the Ring (2001): selected audio stream is not the first audio stream and direct play stream selection is not enabled
Dec 23, 2020 23:54:08.443 [0x7f8b8ba87700] DEBUG - [Transcode] MDE: The Lord of the Rings: The Fellowship of the Ring (2001): selected subtitle cannot be converted to a compatible format, burning into video stream
Dec 23, 2020 23:54:08.443 [0x7f8b8ba87700] DEBUG - [Transcode] MDE: The Lord of the Rings: The Fellowship of the Ring (2001): Direct Streaming is disabled, so video stream will be transcoded
Dec 23, 2020 23:54:08.443 [0x7f8b8ba87700] DEBUG - [Transcode] MDE: The Lord of the Rings: The Fellowship of the Ring (2001): no remuxable profile found, so video stream will be transcoded
Dec 23, 2020 23:54:08.443 [0x7f8b8ba87700] DEBUG - [Transcode] MDE: Cannot direct stream video stream due to profile or setting limitations
The choices are:
Re-encode the video and burn the subtitles in permanently PLUS convert to H.264
Buy a much larger NAS
Make certain you don’t use HEVC/H.265 on that NAS. It is not capable.
Enable more capabilities in the player settings
I worked around it by making my Nvidia shield as a PMS and added the movies folder to its library.
Now i was able to watch the movie in 4k UHD, only without subtitles. When i enable them, it starts buffering forever. Not sure why.
Also with Shield as a PMS i notice the following"
LC C9 native Plex client does not play the movie at all.
Nvidia shield clien plays the movie but with subtitles off.
Ipad. and Iphone play the movie perfectly fine even with subtitles on.
