Qnap NAS will not install Plex but a blue screen (not BSOD)
It appears i have corrupted something. I moved finished tv shows from A-K and L-Z folder into a new folder named ENDED. I thought all good but found some series that had been watched were now unwatched. So I thought ok I have a backup from 2 days before so copied the db file (like I had done so many times before) to over-write the failed version ( that I thought corrupted ). There started the problem as plex would no longer open. And updates of app, reboots , etc,etc brought up the blue screen.
I have since tried a dozen versions and installs and when I click I get this blue screen. Not the BSOD just a plain blue with nothing on it . I have tried the default NAS version and several older version so it is not version related. multiple reboots, removals , re-installs…
Occasionally I get -
This site can’t be reached
192.168.1.182 took too long to respond.
Try:
ERR_CONNECTION_TIMED_OUT. It feels like its a permission thing but I have no idea .
I have several backups of com.plexapp.plugins.library.db that hopefully will have all my watched media still there. It feels like a permission thing but I cannot work it out
It maybe Chuck’s plexdata thing from awhile back but I cannot find the original post and details.
I have had plex for 10 years and never have I been offline for more than 10 hours . Now going into day 2 .
HELP !!
@spikemixture
Can you stop Plex and then manually grab whatever it has for logs from the PlexData/Plex Media Server/Logs directory (use FileStation)
Thanks Chuck,
logs from my most recent reinstall.
Mar 16, 2023 22:34:50.192 [0x7f31cfd93b38] INFO - Plex Media Server v1.30.0.6442-5070ad484 - QNAP TS-1277 x86_64 - build: linux-x86_64 qnap - GMT 08:00
Mar 16, 2023 22:34:50.192 [0x7f31cfd93b38] INFO - Linux version: QTS 5.0.1.2277, language: en-US
Mar 16, 2023 22:34:50.193 [0x7f31cfd93b38] INFO - Processor: 16-core AMD Ryzen 7 PRO 1700 Eight-Core Processor
Mar 16, 2023 22:34:50.193 [0x7f31cfd93b38] INFO - Compiler is - Clang 11.0.1 (https://plex.tv 9b997da8e5b47bdb4a9425b3a3b290be393b4b1f)
Mar 16, 2023 22:34:50.193 [0x7f31cfd93b38] INFO - ./Plex Media Server
Mar 16, 2023 22:34:50.193 [0x7f31d3545ad0] DEBUG - BPQ: [Idle] → [Starting]
Mar 16, 2023 22:34:50.202 [0x7f31d3545ad0] DEBUG - HttpServer: Listening on IPv6 as well as IPv4.
Mar 16, 2023 22:34:50.203 [0x7f31d3545ad0] ERROR - HttpServer: Error binding acceptor: Address in use
Mar 16, 2023 22:34:50.203 [0x7f31d3545ad0] ERROR - HttpServer: Error opening acceptor on IPv6, falling back to IPv4: Address in use
Mar 16, 2023 22:34:50.223 [0x7f31d3545ad0] DEBUG - [JobRunner] Job running: /share/CACHEDEV3_DATA/.qpkg/PlexMediaServer/CrashUploader “–directory=/share/CACHEDEV3_DATA/.qpkg/PlexMediaServer/Library/Plex Media Server/Crash Reports/1.30.0.6442-5070ad484” --version=1.30.0.6442-5070ad484 --platform=Linux “–platformVersion=QTS 5.0.1.2277” --serverUuid= --userId=NOUSERID --sentryUrl=https://o17675.ingest.sentry.io/api/1233455/minidump/ --sentryKey=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx --vendor=QNAP --model=x86_64 --device=TS-1277 --allowRetries=0
The friends are still in your account (Settings - Users & Sharing … upper left corner).
Thanks again. Yes I found them.
So here is where i am today
I have 2 qnap NAS TS1277 (192.168.1.77) and TVS1282 (192.168.1.82)
I have installed old, new and in between version on both over the last 3 days.
I have tried installing on the QTS volume and their own SSD volume.
The media is safe on the HDD’s
Now after an install when I click Plex from either box I get this with the the ip being that boxes address.
192.168.1.82 refused to connect.
Try:
Its appears be a permissions thing but I am lost.
What was your thing way back when installing on Qnap you need a plexdata folder ??
The DB i have backup seems to be ok as I have installed plex on a PC and copied over the appropriate db and it shows my watched .
It shows my local friend in the correct place but those outside my network show but are not ‘joined’
about to call it a night, but –
  1. Create a Shared Folder named “PlexData” (exact case) anywhere you like.
  2. Apply any permissions you deem appropriate/necessary to that shared folder
  3. Stop Plex in App Center
  4. Start Plex (or attempt to start it)
    – The attempt to start is what populates PlexData
  5. Stop Plex
  6. Now you can open, in FileStation, PlexData → Plex Media Server (which is normally hidden inside the package area)
  7. Right-click ‘Logs’ → “Compress” (make a ZIP file)
  8. download
  9. attach here.
deleted
Hi Chuck
Still happening on 1 NAS
Logs.zip (129.4 KB)
Hi chuck I have your DB Repair but i am too dumb to know where it goes and how to run it .
I have looked at the read me but cannot find out how to run it .
I have this folder in /share/CACHEDEV1_DATA/Public/PlexDBRepair-master
Is that right ?
Now what ?
